Like Tree4Likes
Tamiya TRF417
Old 08-26-2013, 06:21 PM
  #5821
vivo quevas's Avatar
Trader Rating: 19 (100%+)
I will trade you a .5mm spacer for the servo mount I gave you.
vivo quevas is offline
Old 08-26-2013, 07:07 PM
  #5822
Typeone's Avatar
Trader Rating: 50 (100%+)
I was going to give it to George cause he bought the x chassis and top deck from me and I told him I was going to give it to him as soon as I got my TRF mount. Ill buy one off u tho.
Typeone is offline
Old 08-26-2013, 07:55 PM
  #5823
No problem I will give you a washer I thought since you weren't going to use the mount. I am using a gold servo mount on a Tamiya car.
Maybe you could trade me the blue one for the gold one. George would understand I hope.
Old 08-26-2013, 08:24 PM
  #5824
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Does anybody have a .5 spacer I can buy I want to raise my top deck but don't want to spend $8+ for a set of four when I only need one. Or is there another alternative?
Check fresno ag
Just received my TRF servo mount and I was wondering the hole on the side is it there to put another belt tensioner and if so do I just buy the same bearings that the top tensioner has?
Think its for the battery stop so lipo won't hit the lower side front belt
Mr.juarez is offline
Old 08-26-2013, 09:45 PM
  #5825
Tim, check this post I made a few days ago.
http://www.rctech.net/forum/12447432-post5781.html
dizope is offline
Old 08-26-2013, 11:21 PM
  #5826
ATLASCOPCO's Avatar
What o rings are being used in the gear diff now
Guys
Seem to have kyosho ones in my head
Also do you have part numbers please
ATLASCOPCO is offline
Old 08-27-2013, 01:16 AM
  #5827
I use the Kyosho ones, they work well.
Here is a guide
http://www.thercracer.com/2013/07/ho...ear-diff.html?
Qatmix is offline
Old 08-27-2013, 01:32 AM
  #5828
Kellen Guthrie's Avatar
Hey guys just switched over to tamiya and bought a 417. What's a good setup to start with for the tamiya track?
Kellen Guthrie is offline
Old 08-27-2013, 07:31 AM
  #5829
Racing4Evo's Avatar
Mod or spec?
Racing4Evo is offline
Old 08-27-2013, 05:59 PM
  #5830
OnRDPassion's Avatar
Trader Rating: 59 (100%+)
Shoot me your email I will send you mine.
OnRDPassion is offline
Old 08-27-2013, 07:38 PM
  #5831
Originally Posted by Racing4Evo
Mod or spec?
13.5t to start with then i'm gonna run a 4.5.
Old 08-27-2013, 08:03 PM
  #5832
Racing4Evo's Avatar
I can't find my setup its been a while, but it is VERY similar to this:
http://www.petitrc.com/reglages/tami...aukaa20110611/
The differences:
-LTC-R lightweight
-4mm ackerman spacer
-HPI Silver F&R
-Front Spool
-Front DCJ
Easy to drive setup that also works very well on carpet at TQ with spring and toe adjustments.
Old 08-28-2013, 08:42 AM
  #5833
Jochim_18's Avatar
Fresno boys flooding Tamiya forum lol... On the flooting servo mount you guys need to figure out if the holes align correctly if not you need to drill extra hole to secure and to keep it from moving. Shock weight I would start with 35wt all the way around if you are running stock 17.5 at hobbytown Fresno.
Jochim_18 is offline
Old 08-29-2013, 07:18 PM
  #5834
nolo148's Avatar
When I put .3 shims on each side of the diff and same the gears to 3.57mm, the diff feels kinda tight, not very smooth. What am I doing wrong? I'm not over tightening the screws, I'm using kyosho o rings, tamiya .1 shims and I'm using v5 out drives.
nolo148 is offline
Old 08-29-2013, 07:58 PM
  #5835
CraigM's Avatar
Trader Rating: 34 (100%+)
If everything is new then the gears just need to be run in. If the internals are not new then replace the gasket.
Also do yourself a favour and chuck the tamiya shims in the bin and use 1 x 0.3mm TDX or similar each side
CraigM is offline
