Like Tree4Likes
Tamiya TRF417
Old 03-14-2013, 06:28 PM
  #4906
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Originally Posted by CraigM
- I ran a grub screw in the front motor mount hole like Viktor at the GC ETS
have a pic of how this is done?
VooDooPH is offline
Old 03-14-2013, 09:07 PM
  #4907
CraigM's Avatar
Trader Rating: 34 (100%+)
Like this...
CraigM is offline
Old 03-14-2013, 09:25 PM
  #4908
VooDooPH's Avatar
Thanks! somehow, i couldn't get through to the kentech blog.
VooDooPH is offline
Old 03-15-2013, 07:30 AM
  #4909
dMITIj's Avatar
Hello all.
what is the difference between these two tamiya trf417v5 and the tamiya trf 417wx?
Best Regards.
dMITIj is offline
Old 03-15-2013, 10:50 AM
  #4910
narcotiks's Avatar
Originally Posted by dMITIj
Hello all.
Best Regards.
Its the same car, it was called the wx for a little while then the renamed the v5 when photos etc were released!
narcotiks is offline
Old 03-15-2013, 11:02 AM
  #4911
dMITIj's Avatar
oohh okay thanks
dMITIj is offline
Old 03-17-2013, 09:27 AM
  #4912
nolo148's Avatar
Default Cracked chassis
My chassis cracked where the rear suspension mount is, should I buy the 417x lower deck or go for the v5 lower deck and servo mount? Assuming that all the bulkheads from the 417x fit onto the v5 lower deck plus the new servo mount.
nolo148 is offline
Old 03-17-2013, 10:38 AM
  #4913
SS LS1's Avatar
Trader Rating: 23 (100%+)
The V5 chassis is nice but if I replace my 417x chassis I will likely try a Smokem 417fx chassis, or if you can wait get the new Raceberry conversion talked about a few days ago.
SS LS1 is offline
Old 03-17-2013, 10:47 AM
  #4914
nolo148's Avatar
Out of stock I will be running on carpet and asphalt and I'd need it by April so probably wont be able to get the Raceberry conversion. How about the 417mx?
nolo148 is offline
Old 03-17-2013, 10:57 AM
  #4915
Dusttt's Avatar
Trader Rating: 144 (100%+)
Ran the car for the first time yesterday at West Coast and it was a handful. I threw everything but the kitchen sink at it and it was ok by the end of the day. It was just super twitchy. I came from a t3,t2011,and 12 and then a tcxx. I was used to the other cars having a great kit setup. This is my first Tamiya(always wanted one) so I will get it. Anyone have a set up for west coast?
Dusttt is offline
Old 03-17-2013, 12:46 PM
  #4916
Trader Rating: 32 (100%+)
WCRCR in La Mirada? If so, I can help you out.
ittjv is offline
Old 03-17-2013, 01:55 PM
  #4917
OnRDPassion's Avatar
Trader Rating: 59 (100%+)
This is my set-up for west coast and it seeming to work pretty well. The car definitely has a lot of traction. On the current layout I was able to get in the 13.7-13.8 with 13.6 being a fast lap when the track was pretty green. Feel free to come over and talk to me about your car the next time you are there. I would be more than happy to help you out.
- J
File Type: pdf
OnRDPassion is offline
Old 03-17-2013, 07:44 PM
  #4918
Dusttt's Avatar
Yes sir WCRC. Thanks
Dusttt is offline
Old 03-17-2013, 07:45 PM
  #4919
Dusttt's Avatar
- J
Thanks!!!!
Dusttt is offline
Old 03-17-2013, 07:48 PM
  #4920
SS LS1's Avatar
The Smokem 417MX chassis is a little stiffer for med to high grip tracks so you will have to make that call if it is right for you. It is a high quality piece I have been told.
Exotek used to sell a real nice chassis called the 417XS (extra soft) but I searched all over and cant seem to find one for you. Like this >>
http://www.quantumracing-rc.com/inde...productId=2710
You can get the CSO chassis or complete chassis kit which includes lower and upper decks along with the center servo mount cheap, but it is not all carbon fiber material. It has fiberglass sandwiched in the middle of the chassis plates so you have to decide if you are ok with that.
$49.00 http://www.rc-mushroom.com/product_i...hassis-p-24102
or $45.00 http://www.rc-mushroom.com/images/CSO-TA-1005.jpg
The chassis kit is only $81.00 http://www.rc-mushroom.com/product_i...n-type-p-25485
Personally I would go with something of a better quality though like the Reedy Chassis plates as they are Tamiya quality.
Only $60 from Speedtech just the deck will be stiffer at 2.5mm thick vs. 2.25 for stock 417x chassis. http://www.speedtechhobbies.com/inde...roduct_id=2201
The V5 chassis plate is available for about $80 but it will also be a little stiffer than your 417x chassis plate was, and you will need the $30 TRF center servo mount too or some shoe goo to mount your servo. Lots of choices!!
SS LS1 is offline
