Stronger diffs for TC3? >
Old 08-07-2010, 06:49 PM
SloRacer1080's Avatar
Trader Rating: 15 (100%+)
Default Stronger diffs for TC3?
Hey guys, I have a TC3 with the Traxxas Velineon brushless system in it. It's got plenty of torque and speed, (gps confirmed 33.1 mph). But problem is, it has ball diffs. I have to run them tight to keep them from slipping like crazy. But by doing that it handles like crap. The rear end just slides out while turning way too easily.
I have already destroyed 1 rear diff. The thing got so hot it melted the diff rings into the outdrives, which then threw them off center and it started to eat the ring gear, and so on.
When I went to the LHS to get a new rear diff, they didn't have any TC3 ones. So we looked through the Associated bins, and found a B44 diff. The whole thing in a package. It was different, but looked like it should work. It has longer metal outdrives, the rings are just circles without the D shape, the gear was a different material, but the same exact gear, and the thrust bearing nut was completely different.
So of course the combination of all the different elements made it a bit tricky to get it in there, but I made it work. All I had to do was cut the thrust bearing spring in half, after 2 hours of trying everything else.
And I have run a few packs through it and it seems to be fine, just still handles funny cause the diffs are tight.
What I am getting at here, is there anything else I can use instead of a ball diff? Not a spool, that would just make it handle worse. Like are there any normal gear style diffs that could maybe fit in the TC3? Or maybe some really strong ball diff?
Hopefully someone knows something I don't.
SloRacer1080 is offline
Old 08-07-2010, 10:47 PM
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Get the lightened steel outdrives
liljohn1064 is offline
Old 08-08-2010, 12:24 AM
sliding_josh's Avatar
Trader Rating: 21 (92%+)
Yep I went to the LHS and bought the steel out drives but still diferent than stock!
sliding_josh is offline
Old 08-08-2010, 01:15 PM
Lightened outdrives affect it how? Is it because there is less mass to move, so the diff isn't stressed as much?
Old 08-08-2010, 01:26 PM
BCbud's Avatar
Trader Rating: 37 (100%+)
Good day!
There is a compleat steel diff that will fit, I think it is from the NTC3. I had one in the front of my TC4 And it worked well.
BCbud is offline
Old 08-08-2010, 03:18 PM
Originally Posted by BCbud
Good day!
Any idea where those can be found? I looked at at least 6-7 different stores with no luck. I did find the heavy duty one way, that was it.
As far as one way's go, if i remember correctly they allow the motor to drive the diff, but the brakes don't affect that diff. Right? So reverse wouldn't work so well with a one way.
Old 08-08-2010, 04:06 PM
trerc's Avatar
Trader Rating: 89 (100%+)
Here's what you need. They are plenty strong enough for that system and you should be able to run the diffs with a normal setting.
http://www3.towerhobbies.com/cgi-bin...?&I=LXNZ98&P=7
trerc is offline
Old 08-08-2010, 05:10 PM
Basically you're saying as long as I use steel outdrives, I should be fine? Cause if thats the case, I've already got them on the new rear diff. Problem is with the steel outdrives, they use a thrust bearing nut holder that is supposed to lock into the slots on the outdrives. Instead of the recessed nut that sits in the plastic outdrives. Well if you use it the way they want you too, the screw never reaches the nut.
Long story short once i got it to work, i am now limited on my camber adjustment. The cv shaft goes into the drive cup enough that it just barely makes contact with the screw head if i put a few degrees of neg camber on it. I'm no expert of on-roads, but that can't be healthy, so it's pretty much set at 0-1 degree right now to avoid that.
Old 08-08-2010, 06:15 PM
trerc's Avatar
And this will solve that problem
http://www3.towerhobbies.com/cgi-bin...?&I=LX2869&P=7
trerc is offline
Old 08-08-2010, 06:32 PM
I just happened to stumble across your thread.
you can find parts for older TC3/TC4 at losi / associated parts house.
I did a quick search and they have the steel diff kits / parts.
Good luck
LaxRacer is offline
Old 08-08-2010, 06:44 PM
(Disclaimer: I am not trying to be difficult, Trust me I appreciate the advice)
Unfortunately, thats the same nut holder thing that came in the b44 diff I have. I understand how it should work, but it doesn't. If you look at the piece, the nut is closest to the screen. That side has to face the inside of the diff.
When I put it in the long outdrive, the screw doesn't reach it. If I put it in the short outdrive, it blocks the cv shaft from going in to the drive cup.
What I had to do was put it in the long outdrive, and push it all the way down, it kinda broke the nubs off, and it sunk into the outdrive enough to not be in the way.
The factory diff had just the locknut by itself, that sat into a hex shaped hole at the inner-most part of the outdrive. I have yet to find something similar.
This is the kit I used to replace the rear diff. This whole thing is in the tc3 now.
http://www3.towerhobbies.com/cgi-bin...?&I=LXSYX5&P=7
By looking at the outdrives, they look just like the lightened ones, and have the chamfers in them.
Looking over Towers diff list, I found this.. http://www3.towerhobbies.com/cgi-bin...?&I=LXTLW1&P=7
Its a diff from a Mini MGT. That is what I would really like to have in the car, not necessarily the mmgt one, but that design.
Old 08-08-2010, 06:51 PM
Good luck
Hmm, just did that. What is being called a lightweight steel diff, looks like exactly what I already got. Only mine was labeled factory parts for a B44.
So all in all, it appears I already have the best ball diff I can use in this thing?
Old 08-08-2010, 06:59 PM
simplechamp's Avatar
Trader Rating: 73 (100%+)
There is this: http://cgi.ebay.com/NEW-Associated-S...ts_Accessories
Then there is the lightweight version, but either way it should do the trick.
simplechamp is offline
Old 08-08-2010, 07:11 PM
All of them are still ball diffs. Only thing that seems to change in the packages is the outdrives, lightened or not. That and the color of the gear.
Old 08-09-2010, 02:50 AM
trerc's Avatar
Ball diffs will work, I guarantee it. To have the issues you are having you can't be assembling them correctly, I don't know how else to say it. The TC3 and its ball differentials have pretty much stood the test of time and over that time people have thrown a lot more motor at them than what you are with no issues.
trerc is offline
