Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 12-11-2020 | 06:10 PM
  #10231
Metalsoft why don't come race TCS with us. TCS is exactly what you wanted. Racing fun rc cars with non sponsored drivers. You even get to win prizes and a free trip to race in Japan.
Originally Posted by Metalsoft
Don't know that they have. But yeah, no entry class, people just starting are not wanting to get into it. Race what you want, obviously it is working what ever we are doing. *sarcasm*
New guy: How much does these cost
Vet: Anywhere between $500 and $1,000
New guy: If I get one of the $500 will it be any good?
Vet: most likely not because that guy sponsored by Reedy, RC kicks blah blah blah has about $2000 in his, plus brand new motors etc and kicks everyone's ass.
New Guy: Later amigo
Fair is perception in RC. Most sponsored guys race all the classes anyway. Just let the ones like myself that enjoy racing, and are middle of the road racers, enjoy a class I don't have to worry about that. 13.5, 17.5, 12th scale, are already there and established. You want to work on your skill to get up to those classes, but if you break their sprits before they get there, you are hurting the nature of the sport. This is suppose to be fun, and exciting. Not, I have no chance to finish in the top 3, week after week.
I guess you could lock down something like Tamiya Trucks to the new guys, but what is the fun in that. Just my opinion. Just don't cry when the sport doesn't grow.
simple likes this.
v_squared is offline
Old 12-11-2020 | 07:02 PM
  #10232
Suspended
Thanks man,
Yes sir that is on my list for next year. I have already reached out to a few shops for a schedule next year. Can't wait to come race. I have 4 tracks in mind to visit next year. This is how it should be!
Metalsoft is offline
Old 12-12-2020 | 11:29 AM
  #10233
Default USGT
USGT racing tomorrow in San Marcos, CA!
Hopefully we get at least 10 out of 40ish drivers have a USGT car.
The others are racing 17.5, euro, F1, and minis.
Xrayray is offline
Old 01-14-2021 | 09:15 AM
  #10234
MattTLR's Avatar
I know this is going back years in this thread but I just built my first kit TLR 22 5.0 AC and i bought the turnigy trackstar 17.5 esc motor combo. This thing is slow as shit I'm the slowest on the track. The pros at my local club said theres something wrong and it's a slug and shouldn't be this slow. They looked at my setup and said it shouldn't be this slow because everything else looks perfect. Does this motor esc combo just suck that much?
MattTLR is offline
Old 01-14-2021 | 09:21 AM
  #10235
Interesting, a 17.5 turn motor should smoke a USGT 21.5 turn spec motor. So I'm guessing that your club runs 17.5 turn motors in USGT. If your motor is slow compared to other 17.5 motors, then I'd take a close look at the timing. See if one of the pros will put your motor on a motor analyzer and compare your timing to the guys that are a lot faster than you. Most of my 17.5 and 21.5 motors are timed around 45 degrees. But that was one of the good things about the USGT spec motor. It has fixed timing which means one more thing you don't have to worry about! If it's not timing, then look at the gearing. The fast guys might be running a different final drive ratio than you are.
Cancun Tom likes this.
glennhl is offline
Old 01-14-2021 | 11:33 AM
  #10236
simple's Avatar
This is an on-road Thread for USGT touring cars....You might try posting in the thread specific to your buggy (TLR 22 5.0).
Assuming you have proper gearing, it might be as simple as re-calibrating your transmitter to the ESC by following the instructions included with the combo.
The ESC and motor you have is statistically perfectly adequate. You are experiencing a setup issue.
gigaplex likes this.
simple is offline
Old 01-14-2021 | 02:58 PM
  #10237
CL's Avatar
CL
Those Trackstar 17.5T motor are really slow. Those are 8-9 years behind in technology. I would suggest getting what the fast locals are running. They could also help you with the correct timing and gearing.
mariob62 likes this.
CL is offline
Old 01-16-2021 | 08:23 AM
  #10238
To the OP, I just saw that you are running a buggy, not an onroad car in USGT. So PLEASE do NOT run 45 degrees of timing in an offroad car, you will burn up the motor. And please don't ask me how I know!
glennhl is offline
Old 01-16-2021 | 02:22 PM
  #10239
WhiteLX's Avatar
Not USGT related, but figured I'd respond to the new guy to help him out.
I have one of the older silver Trackstar 17.5 motors. I picked up a motor analyzer and was doing some testing today. The TS 17.5 has a hard stop on the timing and the maximum was 39 degrees. At that timing it was pulling 1.7 amps and did 2447kv at 19337rpm. Pretty bad IMO. Although this is a motor from 2012, it doesn't have much run time. As a comparison, I have a Trinity D4 17.5 and at 35 degrees it pulled 5.9 amps and did 3303kv at 25768rpm. I was curious, so I took the TS 17.5 apart to see if I could advance the timing any further. I removed one of the rotor shims and loosened the timing screws and was able to go over the timing stops. I dialed it in to 6.0amp and that resulted in timing of 49 degrees, 3189kv and 24562rpm.
Before adjustment I had the TS17.5 geared at 69/35 (5.13 FDR) in my TRF201 buggy and it would run forever without getting hot. No idea how it would compare in racing as I've never raced it. If I want to run the new timing level, I'm sure I'll have to gear down and watch the temperatures.
Food for thought and may shed some light as to why the TS 17.5 seems so slow.
WhiteLX is offline
Old 01-16-2021 | 09:52 PM
  #10240
Hope the motor picks up some speed...
bertrandsv87 is offline
Old 01-17-2021 | 01:21 PM
  #10241
gigaplex's Avatar
If the only way you're going to have fun is if you finish in the top 3, then you're setting yourself up for disappointment.
gigaplex is offline
Old 01-23-2021 | 01:31 PM
  #10242
I was about to re-kit to a mid motor car for this reason but I remembered why I started racing which is to simply have fun and go fast. 👍
NutDriver likes this.
Xrayray is offline
Old 01-23-2021 | 04:09 PM
  #10243
Marcos.J's Avatar
Super Moderator
the Spec USGT motor is not that bad on a medium asphalt track the motor is pretty fast between 3.0-3.2,
NutDriver, glennhl and Bry195 like this.
Marcos.J is offline
Old 01-26-2021 | 10:02 PM
  #10244
Snowboard3r411's Avatar
Is a 6000 enough battery for usgt?
Snowboard3r411 is offline
Old 01-27-2021 | 03:35 AM
  #10245
You should be fine. I use a 5800. Also depends on track and weight needed to get to the 1380 grams.
V8 Rumble is offline
