Nomadio Sensor Radio
#16
I was reading up on the whole site and it is indeed roar legal.
As far as it being ugly, well I guess we are used to the traditional look of Transmitters.
I actually see it as less bulky and pretty streamlined.
As far as being expensive?
How much do you spend on a good transmitter? now how much is a Spektrum system?
If you wanted to go 2.4, then this new system may actually be cheaper.
And the fact that you can upgrade the software?
I only see positives with this new product,
however it is yet to be thoroughly tested.
#17
I'm running a 3 year old xr-3i radio. The futaba 3pk would be my only choice of the highend radios out there. So i have to plunk down $320 for the radio then try to sell the module and reciever. Then shell out another 100 bucks for the speckrum setup. I just don't like big radios. I wish there was somthing outhere like my old JR xr3i whith dsm. I dont want all that extra stuff I just want to be immune to morons in the pits that turn on their radios.
#18
#19
You don't have to use the sensors....
#20
#21
Another thing that not so great is the size of the transciever. If I'm running 8th scale buggy or even nitro sedan its not a big deal. But in my TC4 my GT-7 and a R-135 reciever wont fit unless I stand up the reciever. If they would come out with a smaller reciever for electric cars I would buy one for sure. Its 50x33x22mm thats a big reciever. My R-135 is thinner and narrower.
#22
Remember the transciever does 2 way communication between your car and controller.... From what I've seen the Spektrum's transciever is a little on the large size also... BTW... once you go to a GUI system running on 2.4ghz the radio you put into the car is no longer a reciever, it's now a transciever.... I'm sure the size will come down as technology advances more..... I have Novak XXL's in all of my cars and I manage to get them to fit....
#23
I just wanted to let everyone know that I am testing the Sensor. It has been working great for me, with no glitching at all. While some may say its expensive, it's a great investment. If you have any questions, I may be able to answer them.
#24
Can you give us a run down on how the features are compared to let's say a 3PK or M8???
I don't just race EP on road... I have my MT's, I have motorcycles and I have 5th scales, etc.... My 3PK does a great job of controlling those vehicles and gives me the settings to make them handle exceptionally... I like the brake mixing for my 5th scale cars and motorcycles that I have both front and rear brakes on.... And so on....
#25
How about some pics of the system as installed in your car ?? Is the radio officially available and shipping ?? Or is the beta testing still ongoing??
#26
Currently, there is only beta testing going on. On the www.nomadio.net site, you can pre-order your Sensor.
#27
I really hope Nomadio makes it. The sheer coolness of the radio, coupled with a LARGE and easy to read screen is undeniable.
If they get the Rx smaller for 1/12th applications, I'll be onboard.
Also, since Nomadio is a licensed defense contractor, they should be around for a very long time. The fact that they do more than R/C gives me confidence as a consumer.
Of course, we have yet to see what Sanwa, Futaba, KO and JR are cooking up on the DSM front.
You can bet they will be releasing DSM radios before the years end.
#28
Here is the rundown of the basic features as stated on the Nomadio site-
"Radio Type : Digital Spread Spectrum 2.4 Ghz
Range: 2000 ft.
Frame Rate: 70 Frames per second
Latency: 13 millisecond max, 7ms typical
Channels: 3 (base) up to 32 (expansion)
Weight w/Batteries: 784 g
Rechargable Batteries: Included - NiMH
Charger: Included
Model Memory: 8 Named, custom graphics+sound
Controller Batt Voltage Monitor: Graphic, Real time
Car Batt Voltage Monitor: Graphic, Real time
Timers: Operation and Lap Timers
Trims: Adjustable Trims and Sub Trims
Controls: Dual Rate, Endpoints, Exponential
Mixing and Servo Speed Adjust on all channels
Anti-Lock: Brake Anti-Lock with Cycle, Delay, Depth
Idle up: Yes
Speaker: .75” w/headphone jack
Audio: Programmable WAV file audio and tones
Tactile Alarm: Programmable vibrator
Display: Movable Backlit monochrome LCD display
Resolution: 128x64 display resolution
Auto Modes: Auto Display and Display Only
Presets: Fail Safe, Auto Start
Telemetry: 3 channels of real time telemetry
Telemetry sensors included: Speed, Temp, Battery
Servos supported: Analog and Digital
Left handed operation : Yes (user modified)
PC : Serial connection for customization, analysis and updates
Antenna: Fixed 3” antenna
Architecture: Software upgradable"
The Sensor is software based, and most things are probably possible. It's just going to be a matter of whether enough people want something.
As for the pictures of the reciever, I'm gonna have to hold of on those since it is still a prototype and the production model will look different than the one I am currently using.
Range: 2000 ft.
Charger: Included
Idle up: Yes
#30
I also thought I would let you guys know of that the weight posted on the site is incorrect. The actual weight is 674 g. This is lighter than almost all highend radios. For a comparison in weight, the mx3 weighs about 706 g.
