Diff Bearings
I wet sand the rings with 400 weight. This allows you to run the diff a little looser without slipping. Keep the diff smooth/maintained - this makes a huge difference..
If you study the rings you will see a big difference in how they wear when using ceramic balls verses steel balls. (Tungsten will do better than chrome steel but nothing is better than ceramic)
