Unusual front tire wear
#16
Okay..
So I just looked at my camber with a set of home made ABS drift wheels I made. These wheels basically have square edges and are hard so when I steer, I can see the camber angles quite clearly.
The outside (turning) wheel's inner edge is where the wearing is happening.
I changed my front camber to 0 when suspension is neutral, it's actually positive when fully lifted. No droop screws yet.
I see less caster induced camber when the wheels are locked into a turn. I think this help, but I think this is just how wheels will always wear out.
I can try a flatter caster with shims, later the next time I rebuild. But the turning blocks have their own angles built in.
Thanks y'all.
Thanks y'all.
