custom faceplates turbo 30
Were do I get them?
if you have a scanner and colored printer (or know someone who does), you can make your own faceplates. i havent actually made one yet, but i am planning to. someone posted the instructions here a couple of months ago. ill try to find it. but from what i recall, you just scan the picture that you want to appear on your faceplate. then, line up and mark the T30 buttons, so youll know which button is which. after finalizing your design, print it and cut out the part that lines up with the T30 LCD. have the printout laminated and then trim it to fit the T30 case. youll have to remove some screws on the underside. BUT, check first if this will invalidate your warranty (if the unit is still under warranty.)
need to find out who made the ones for kinwald, Drake ect ect
no1uno - rcbase.com i beleive. They are the guys who made Futureal's face plates. They are pretty nifty.
Thanks guys that is the one I was looking for
Actually, the faceplates on Kinwald, Drake, Francis, Dunbar....... and quite a few others are made by Spyked/Chaos Racing
He has them pictured on the site.
Thanks for the plug Skip!
There is an FAQ on my website that explains how to get one. To date, I've done close to 100 different racers, including some of the biggest names in the business. (Including every Team Losi driver with a "kit" named after them!)
I've just applied for a patent on the PitPlate for those of you without a Turbo30, you can dress up that folding fluorescent light. Check out the site for details...
http://www.spyked.com
