Fantom Dyno
Fantom Dyno
A friend loaned me his dyno but said i need to get a car battery to use it I used my bulldog 30a power supply and it worked fine for stock motors that'a all that i run anyway .I was then told that because of not using the battery that the numbers wouldn't be accurate is this ture
Thank in advance.
Thank in advance.
Yes, this is ture. (true) What happens is the motor, on start up, draws more amps then your power supply can handle and gives different numbers than if you had used a battery that can spike at 60 plus amps! I hope this helps. You can use a power supply, but it is not as accurate.
To get accurate numbers you need at least a 45 amp power supply for just stock motors. Ideally they say to use a 75 amp power supply.
Car battery works, just make sure it is always charged.
Jeff
Jeff
thanks eveyone i'll look at wal mart for the battery and a charger.
Hey sport, tractor battery will work fine for the stock motors.
Thats what I'm goimg to pick up and a charger yuppie said he has battery but the charger isn't all that good manta had it so who knows what shape it is in . pm me so I can get your home number I need to ask you some questions if you don't mind.
