Old 03-06-2010, 03:58 AM   #1
Tpg racer's Avatar
Default Carbon fibre stickers on bodyshell
Might not be an appropriate thread here but I'm an electric racer so it feels like home here...
So how do guys apply carbon fibre stickers on your bodyshell? Is it glued onto the bodyshell from the outside or from the inside?
Most stickers i found has adhesive on the back which means it needs to be glued onto the bodyshell from the outside... is that the right way of doing so?
Tpg racer is offline   Reply With Quote
Old 03-06-2010, 06:30 AM   #2
Yes, apply decals on the outside or paint CF look on the inside.
AreCee is offline   Reply With Quote
Old 03-06-2010, 07:44 AM   #3
Tpg racer's Avatar
If you apply carbon fibre sticker on the hood from the outside, wouldn't it easily damaged when you flipped the car upside down?
Old 03-06-2010, 09:23 AM   #4
rced1's Avatar
Trader Rating: 17 (100%+)
Yes, especially racing on asphalt. That is a part of racing RC.
Slow is fast.
rced1 is offline   Reply With Quote
Old 03-06-2010, 09:37 AM   #5
Don't flip.
Old 03-06-2010, 11:18 AM   #6
Tpg racer's Avatar
Don't flip.
Haha nice advise but sometimes its easier said than done....
Old 03-06-2010, 02:45 PM   #7
94eg!'s Avatar
Yes the self adhesive stuff will get damaged super easily. The adhesive isn't very strong either so it's very likely to peel of the smooth lexan. That stuff is better for covering other things like servo & receiver labels or rough plastic...
What your looking for is a special mask that allows you to make your paint job look like carbon fiber. People use a sheet of non-slip shelf liner from a home store that looks like a small checkerboard. You place a piece of that sheet inside the body after you finish all your masking. Tape it in place and give the body a very light dusting of silver spray paint (yes on the inside). Then you remove the checkerboard mask and re-spray the area with black. Once finished, the painted area looks just like that faux carbon-fiber decal sheet, expect it won't get damaged when you flip over...
94eg! is offline   Reply With Quote
Old 03-06-2010, 05:56 PM   #8
I'm assuming that he has a pre-painted body.
Old 03-06-2010, 09:29 PM   #9
94eg!'s Avatar
Perfect excuse to get a new body...
But if it was pre-painted, why would he want carbon decals with the adhesive on the front?
Old 03-06-2010, 09:40 PM   #10
Tpg racer's Avatar
Its not pre-painted... but a friend of mine has some carbon fibre sticker sheet lying around... so its free... thats why I asked...
Old 03-06-2010, 09:41 PM   #11
Tpg racer's Avatar
What if i use the carbon fibre sticker, put some clear adhesive on it and stick it from the inside instead... can this be done?
Old 03-06-2010, 11:47 PM   #12
94eg!'s Avatar
Most likely full of bubbles...
