-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
Soviet 04-20-2005 12:38 PM
Why don't they just sell the Hammer as a stand alone kit?!?!? I've never understood why anyone would want to buy say a new L4 and THEN pop ANOTHER $150 on a "conversion" kit that you can't buy replacement parts for...
It seems silly to me. :rolleyes:
theisgroup 04-20-2005 12:42 PM
some companies can not purchase the front end set from Assoc. and purchasing the part as part would rack up the price to make a conversion not financially sound. also the axle parts are the same problem.
jag 04-20-2005 12:48 PM
Re: Re: Hammer
Originally posted by JDXray
Ya you can strap in your batts with tape.
Yeah but I don't want to use tape. Who makes a battery mount?
JDXray 04-20-2005 01:23 PM
Re: Re: Re: Hammer
Not really true, you can buy the Oldschool frontend for like 20-30 and then just get the rear bulkheads and a screw kit.
Why wouldnt you want to use tape, it holds the best. I dont think its possible for one to make mount for the hara chassis since it is soo narrow. There is no way to but a screw anywhere on the side. Unless you make it like the T force kind, but even then it still seems pretty impossible.
primusblowsgoat 04-20-2005 01:38 PM
rig up some velcro
jag 04-20-2005 02:03 PM
Re: Re: Re: Re: Hammer
Why wouldnt you want to use tape, it holds the best. I dont think its possible for one to make mount for the hara chassis since it is soo narrow. There is no way to but a screw anywhere on the side. Unless you make it like the T force kind, but even then it still seems pretty impossible. [/B][/QUOTE]
Tape is a pain in the butt. I like the rubber band on my CRC but I would prefer a CF brace that was screwed down. I saw one on a car I was racing against and I think that's the ticket.
I think velcro would be too thick if you wrapped it around the chassis... scrape the ground.
Switch Blade 04-20-2005 02:12 PM
I have a set of the "old school" front end for my l3 and was just wonder how you set camber and caster. I dont see how you would do this, unless I am missing somthing. Are there different blocks for different settings?
jumbo360 04-20-2005 02:17 PM
actually there are blocks that are slanted so you get your camber but I think zero with the old school is fine and 10 with the new associated one.
odpurple 04-20-2005 02:18 PM
The idea of a conversion kit, it seems to me, is for people who already have a car and want to move onto something else.
Or, as in my case, you can build a car with the kit and spare parts you have already.
JDXray 04-20-2005 02:22 PM
OD ygpm
odpurple 04-20-2005 02:23 PM
There are 0 and 2 degree shims for ride height and castor adjustment (use two 2 deg shims for 4 deg). For camber adjustments you use header card or shim stock under the inside or outside of the block.
The 0, 5 and 10 degree blocks on the new style front end change the amount of reactive caster, the basic caster setting is made with the white hinge pin shims.
PMK 04-20-2005 08:49 PM
On the old style front end, couldn't you also run a tie brace with a turnbucle and loosen the front end mont screws, dial in some camber and then evenly tighten the screws again. I know crude but doable. I thought the center mount hole was designed to do this.
PK
PMK 04-20-2005 08:59 PM
Rear Supension Limiters
For those using a T plate with discs like an L4 or it's many derivitives, anyone here use the chassis roll travel limiters? These are basically a funny shaped plastic washer that is nested over the damper post and lies between the damper discs. It's outside shape matches the top pod plate cutout for the damper post while the inside shape is modified to limit chassis roll.
Any tips from those that run them. Typically under what conditions, and can the chassis become upset if the side roll bottoms prior th scraping carbon fibre?
Just curious.
PK
Still Bill 04-20-2005 09:31 PM
PMK,
On my L4s , I just use the one with the larger hole for carpet racing. You might try a run without one and then a run with one to get the feel both ways.
Don't use em at all for asphalt.
theisgroup 04-21-2005 05:42 AM
Re: Rear Supension Limiters
Just curious.
PK
i ran one once. it seam to me that it kind of works like a sway bar on a tc. it limits the amount of roll and would break tracktion past that point.
