-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
Still Bill 03-07-2005 09:56 PM
Originally posted by odpurple
the flu's doin great, it's kickin' my ass.
Sorry to hear that. Really wanted to show you my 12L4 car *before* the California Carpet Championships this coming weekend.
Just got all this IRS stuff to take advantage of everything I know.
Will test on Wednesday night at Stockton.
odpurple 03-07-2005 10:16 PM
I may be out there for a visit wed night
Still Bill 03-07-2005 10:18 PM
Only if you wear a surgical mask...he, he...
tc3stocker 03-07-2005 10:19 PM
Od, can you post some pics of your cars. They are sexy:D
Still Bill 03-07-2005 10:20 PM
Especially, a 12L4 with the wiring routed looooow.
tc3stocker 03-07-2005 10:21 PM
all of them, please, unless you don't want to
You should do a picture trail for all your cars. If you are interested send me all the pictures and I will make it.
odpurple 03-07-2005 11:15 PM
Most of the cars worth viewing have already been posted. Cars from my Museum are mostly older spec cars. I'll post new builds as they are completed, if you like.
I don't know what a picture trail is, but if you want to do one, I'll send you photos. PM me or whatever.
Thanks for your interest, guys. Since I'm not a fast driver, I get my jollies from building, so it's fun to share how I put them together.
Bill-
I'm actually working on my first 12L4. I'll post pictures when it's done (with the the looww wiring).
O'D
Soviet 03-08-2005 12:30 AM
Originally posted by picco007
Fire,
JRX-S Bill is correct. There are many things that can make a 12th scale car feel tweaked. First you need to make sure that your tires are the same diameter from side to side. Also it would be a good thing to check ride height at this point too. Second, you need to make sure that your car is in a race mode, meaning the batteries and all race equipment that should be in the car is in the car.
In a 12 th scale car, you should feel even more if there is a tweak in the car. Being that it is small, it's less stabile in my opinion. I hope this helps....
Also...make sure the Diff isn't too loose, as an unloading Diff will send the car to the left on acceleration.
revzalot 03-08-2005 06:35 AM
Speaking of diffs again, another thing I learned from the 12th scale gurus at the track is to add endplay on the diffs. I laterally tighted the diffs too much by slamming the hubs to the axle plates too close. I never lasted the whole race. I'm running new batts btw.
primusblowsgoat 03-08-2005 06:42 AM
so you wanna leave a lil play when you put the clamp on?
also how loose is too loose?
cause i certainly noticed my car pulling left when i nail it, but if i dont just hammer it, im fine
i only tighten the thing enough to where when i grab the tires i cant turn the spur
Still Bill 03-08-2005 06:56 AM
Yes, but mine is only a few thousandths of play. Some others have several thousandths; but, that seems excessive to me.
also how loose is too loose? cause i certainly noticed my car pulling left when i nail it, but if i dont just hammer it, im fine
Not sure if you are asking about endplay or the diff here. Think I answered the endplay above and diff below.
Exactly. I have recently installed 1/8" IRS ceramic balls in the spur and a Slapmaster bearing outside the right hub to make my diff really smooth.
Bill
berger 03-08-2005 11:14 AM
Im picking up a second hand L3 to try some 12th scale, do most of the L4 parts carry over as spares for the kit. Or are spares going to be a problem?
Hyperform Racing 03-08-2005 11:17 AM
they will work on the 12l3. spares will not be a problem
JohnB 03-08-2005 11:21 AM
With exception of the diff ring. The L4 uses big ring diff and L3 small.
The only other difference. beside the axle, between the cars is the upper front a-arm mounting blocks and the chassis.
take care
john
berger 03-08-2005 11:45 AM
Thanks, what am i likely to break, my sedan driving i would say is fairly good, i can go 5 minutes without hitting things anyway ;)
Im going to jump in at the deep end, no wimping out, proper 4 cell modified. :D Now to get some more promatch cells and a nice br00d modified ordered. What sort of winds are you looking at to last the 8 mins on a small/medium track. 10-12 turns?
