-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
chicky03 09-21-2004 06:24 AM
My motor comes right out of the bottom of my L4. I have to turn it a cretain way but no pressure needs to be applied. I put the pinion end in first then have the motor at an angle down and to the back and it slips right in. you may also have to rotate it around to find the sweet spot.
Paul
clinttredway 09-21-2004 06:58 AM
I had the same problem on my L4.. If put the pinion side up first and rotate the motor so that the flat sides are perpindicular to the chassis, the motor should just slide right in. Then you can turn the motor however you need to..
Clint
fatdoggy 09-21-2004 11:40 AM
What motor springs would you run on an 11x2? 4 cells, med sized carpet track.
Thanks. :cool:
barrys 09-21-2004 11:43 AM
red on positive, green on negative
rdub202 09-21-2004 12:14 PM
Clint
very well put clint i was getting there but then the bell wrang in class so i had to go.
fatdoggy 09-21-2004 12:28 PM
barrys - Thanks.
tjcdas1212 09-21-2004 03:56 PM
RC12L4 Front axle
Running TRC foam, the one shim as per manual seems to leave to much play. Should I add more shims to inside or outside of wheel?
barrys 09-21-2004 04:05 PM
adding on the inside slightly reduces steering (since it widens the front track), adding on the outside is neutral
sg1 09-22-2004 05:58 AM
Wait till you see the BMI pod plates and lower pod plate, I had a pinion on my motor and can drop it right in with no twisting or turning... lots of room :)
Wayne
chicky03 09-22-2004 07:01 AM
Yea the BMI rear 12L pod is sweet. Lots more room.:nod:
Paul
barrys 09-22-2004 07:50 AM
rear pod
is there any additional flex'ing as a result of the more room from the rear pod?
Otherwise the obvious question is why the other manufacturers haven't made the same change earlier?
sg1 09-22-2004 08:35 AM
Barrys...
There is less flex do to the left side pod plate is aluminum and mounts in two places on the top pod plate not one like the 12L4. The graphite is also 2 1/2 mm thick which gives more strength, and looking from the bottom the left side of the lower pod plate has an arc to it to give the motor even more room to fall in. Even with the thicker graphite and aluminum left side pod plate, with a light weight Parma body, personal transponder, small reciever and GM speedo the car is under weight by .2 oz.
Wayne
insideline 09-22-2004 09:20 PM
The motor comes out the bottom of my 3.2 knife. No need to remove top screws here.
TJ Bradley 09-22-2004 09:56 PM
best12th
REV 4!
crimson eagle 09-22-2004 10:27 PM
Hi TJ,
How are you doing with your 12th?
Last year you whipped James Arluck into 2nd and me into 3rd at Stockton. I think it was the north west championship meeting. I was running a rev3 at the time. You have any setup tips for the rev4?
Chris Rhodes.
