Originally posted by nashrcracer I use the stock mount and then use a cut off paragon hollow with a old antenna mount on top of the stock one. i never have to replace the stock mount when I brake the antenna off I just grab another mounted antenna and screw up through the stock mount. I'll post pictures later still at work right now. |
1 Attachment(s)
Originally posted by Super Steve finished painting part I have to take the window mask off and do the wheel wells! Let me know what oyu guys think |
1 Attachment(s)
side view
1 Attachment(s)
Front view.
No Airbrush...straight from the Can... cutting the pattern was a pain in the butt. |
1 Attachment(s)
And it's bigger brother...my Pro10:
LOVE the Pro10!!! I am so close to building a Pro10 235mm so I can use the GTP bodies. Right now I have a Speedmerchant 200mm Speed Spec Sedan ready to race at CORCAR!!!I literally need only $20 in parts to finish a Pro10 car.
Ray |
Originally posted by rayhuang LOVE the Pro10!!! I am so close to building a Pro10 235mm so I can use the GTP bodies. Right now I have a Speedmerchant 200mm Speed Spec Sedan ready to race at CORCAR!!!I literally need only $20 in parts to finish a Pro10 car. Ray Anybody got a good set-up for the Yok. YRX-12? it's been 2 years since I ran 12th scale... set-up similar to the L3?..that I previously owned... 12 scale is picking up again at our outdoor tracks... |
whoa holy sh1t thats nice rczombie!
I backed red with black and i used fastchange blue for the white/ thats why it looks blue! are there any decals on those bodies? they are very good |
1 Attachment(s)
I cut the wheel wells and took the mask off the windows
Originally posted by Super Steve whoa holy sh1t thats nice rczombie! I backed red with black and i used fastchange blue for the white/ thats why it looks blue! are there any decals on those bodies? they are very good the Japan Flag is painted into the body. I basically copied the Tamiya Toyota GT1 body that I had. |
Originally posted by Super Steve I cut the wheel wells and took the mask off the windows |
Having some problems with the 12l4. I put the rear tires on (TRC), but even with all the shims included in the box the left side tire rubs on the lower pod. It is just barely now with 4 shims perside, but still noticeable. I could shave a little of the inside of the tire, but I can't imaging this is right. Also, I measured with my calipers and both sides seem to be exaclty the same width. I considered turning the left hub around so that the wider side is toward the inside, but it is clearly shown in the manual with the narrow side in.
Seeing as this is the same rear as the 12l3 with just an IRS axle, I am sure this has come up before. Any help? Also, anyone ever notice that the wheel wells on 12th scale bodies never seem big enough as molded? |
Originally posted by 24601 Having some problems with the 12l4. I put the rear tires on (TRC), but even with all the shims included in the box the left side tire rubs on the lower pod. It is just barely now with 4 shims perside, but still noticeable. I could shave a little of the inside of the tire, but I can't imaging this is right. Also, I measured with my calipers and both sides seem to be exaclty the same width. I considered turning the left hub around so that the wider side is toward the inside, but it is clearly shown in the manual with the narrow side in. Seeing as this is the same rear as the 12l3 with just an IRS axle, I am sure this has come up before. Any help? Also, anyone ever notice that the wheel wells on 12th scale bodies never seem big enough as molded? |
How many shims did you use, and does your left side bearing holder sit flush with the inside of the bulkhead or stick in a little?
I guess the issue that bothers me is that both sides are the same, and going out more is going to be running into the body. |
rear axle install 12th scale style.
Originally posted by 24601 How many shims did you use, and does your left side bearing holder sit flush with the inside of the bulkhead or stick in a little? I guess the issue that bothers me is that both sides are the same, and going out more is going to be running into the body. Step two is space the left rear wheel out till it doesnt touch pod. Dont worry about pics in manual on this one. Just do what it takes. Now measure from chassis centerline to insde of rim on both sides. Hopefully the right is too narrow compared to left!!! Step Three-make both sides of the car symmetrical with shims added on the right. Step four-now place both tires over a ruler and hopefully from outer edge to outer edge cars total width does not exceed 6.75" or so. if it does-cars illegal by ROAR standards. Generalrule of thumb for t-plate cars is to run rear axle as wide as rules allow. Hope this helps and ask if I am being confusing. Ray |
| All times are GMT -7. It is currently 06:13 PM. |
