Like Tree2991Likes
1/12 forum
Old 02-16-2004 | 08:59 AM
  #6721
CypressMidWest's Avatar
Originally posted by dr_hfuhuhurr
Here we go...
CRC Bloody Knife 3.1
Old style front end
2* Caster Shims
Purple Front Tires (CRC)
Grey Rear Tires (CRC)
White Side Springs
80wt Oil w/ CRC Copper Spring
Monster Stock
98t Spur
1.80" Rollout
Car was had too much steering mid corner and Exit. The track was Ultra Racing in Cinci, Ohio. They have new CRC Ozite (Cleveland Stuff).
Blake
Blake try blue side springs with medium or heavy Losi Hydradrive fluid in the tubes. I assume you're running .020 front springs you may wanna try .022's instead. Also were you running an Ascari body? I've found that the Ascari has a ton of steering in middle/exit situations. The Parma Speed 8 is a bit smoother.
CypressMidWest is offline
Old 02-16-2004 | 09:42 AM
  #6722
What gearing would everyone recomend for a carpet oval track that has a 158 ft centerline.I will be running a BloodyKnife With 4 cell with a trinity street spec 21 turn motor.The tires are brand new purples and greys.The gears are 64 Pitch.It came with a 86 tooth spur gear so which pinion wuld you recomend starting with and should i change the spur gear too?
hiflyin is offline
Old 02-16-2004 | 09:55 AM
  #6723
sands's Avatar
I'd ask around your track for what rollout everybody else uses. Most of the better oval guys are probably using dynos to select gearing anyway.
Oh, yeah, this is mostly a road race thread. There is a better oval thread at hobbytalk
sands is offline
  #6724
Recheck that spur, it's probably a 96 tooth. As far as gearing for an Oval, I have no clue.
Old 02-16-2004 | 09:59 AM
  #6725
odpurple's Avatar
Default teeth
I bet that spur gear is actually 98 teeth, that's what Carpet Knives come spec'd with.
and if you look at a 98 upside down, well...
O'D
odpurple is offline
Old 02-16-2004 | 10:01 AM
  #6726
dr_hfuhuhurr's Avatar
Yes, I was using .020 springs up front. Body was a Protoform Speed 8 Reg. Wt.
Problem with the Losi Hydradrive fluid is you can't find the stuff ANYWHERE! If anyone has some PM me...I'll take it off your hands.
Blake
dr_hfuhuhurr is offline
Old 02-16-2004 | 10:25 AM
  #6727
Default 12L4???
Anyone know when it's supposed to be released??
Apex is offline
Old 02-16-2004 | 11:07 AM
  #6728
Blake
Protofrom speed 8? There's the Problem. A Proto Nissan or Parma Speed 8 would have been preferrable. Are you running at the Gate Sunday Blake? If so, Pulfer and I will help dial you in.
Old 02-16-2004 | 11:15 AM
  #6729
Body's the problem? Man! Not like I can find a body around here...
And a Protoform Ascari wouldn't be any better?
Blake
Old 02-16-2004 | 11:32 AM
  #6730
Mike D's Avatar
Blake
dr_hfuhuhurr - Mid-corner to exit steering is much more dependent on chassis setup and tires then the body in 12th stock. I really couldn't say what to switch on a link car setup. I'm 99% sure it's not body though.
I almost made a 'get a t-bar car' joke for CypressMidWest's benefit... but decided against it.
Mike D is offline
Old 02-16-2004 | 11:40 AM
  #6731
speedxl's Avatar
dr-hfuh i am going to agree with mike d
the condition you describing is not of an aerodynamic situation but rather one of a mechanical nature either the car is diffing and or the car may be to stiff and doesnt have enough side roll!
speedxl is offline
Old 02-16-2004 | 11:42 AM
  #6732
trackdesigner71's Avatar
U.S. PAN CAR CHAMPIONSHIPS COMING MARCH 2005...
trackdesigner71 is offline
Old 02-16-2004 | 11:52 AM
  #6733
That may be my problem then...Corally Hard dampner fluid is probably too thick then.
Old 02-16-2004 | 12:17 PM
  #6734
speedxl's Avatar
soften the rear up a little and let the car plant its self the tighten it up little at a time till you find your comfort level!
speedxl is offline
Old 02-16-2004 | 12:23 PM
  #6735
Wouldn't softening up the rear a bit add steering mid and exit? Wouldn't that let more weight shift to the front quicker?
I'm just trying to picture this.
