-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
Matt Howard 01-28-2004 07:19 PM
Originally posted by Randman
Were you running the Ascari at the NW Carpet Champs?
nope, it was the CEFX body. I tried the Ascari this winter and it felt really fast but my lap times were slower than the speed 8 that I was running. Both the speed 8 and the CEFX body are good but I think the CEFX body has just a bit more steering
Randy Caster 01-28-2004 07:28 PM
Hmm, I thought it was the Ascari, we actually switched to the Ascari on Jason's car, but he didn't like the way it felt either. I'm having 2 of them painted up, because I've heard some good things about it as well. Where can I buy the CEFX body?
JimmyMac 01-28-2004 07:56 PM
KT Hobbies!! :D (plug)
Matt Howard 01-28-2004 07:59 PM
www.speedworldraceway.com has the CEFX bodies in stock
Randy Caster 01-28-2004 08:46 PM
Cool. So it handles like an Ascari, but with a hair more steering, correct?
Adam Hartzell 01-28-2004 08:53 PM
Actually, its like a speed 8 only with a little more steering and its much more balanced
Randy Caster 01-28-2004 08:59 PM
Not having run any of these makes it a little harder to know what does what. Is the Ascari a good starting point?
Adam Hartzell 01-28-2004 09:01 PM
The ascari felt real slow to me. it had way to much downforce.
Randy Caster 01-28-2004 09:02 PM
So what would be a good starting point?
Adam Hartzell 01-28-2004 09:03 PM
speed 8. if the car is real loose go to the ascari. if you want more steering go to the cefx
Randy Caster 01-28-2004 09:17 PM
Cool, thanks for the base setup. I usually go with a body with lots of rear grip, and then dial in as much steering as I can, so the Ascari might not be too bad...
davepull 01-28-2004 09:20 PM
keep in mind that the more you have to turn the front tires the more speed you scrub off in the corners
Randy Caster 01-28-2004 09:20 PM
Yep, I know that, but there are ways to dial in steering without going up on the dual rate.
davepull 01-28-2004 09:26 PM
true that. i personally like the parma body. like adam said the ascari seemed to planted. ran it twice and put my parma back on.
Adam Hartzell 01-28-2004 09:41 PM
same here
