i was told that there is not advantage between damper tubes and fricton plates, so i was wondering which one is easier to tune and which one is easier to maintain.
is there any major differences between the major brands of 1/12's or are they all pretty much the same. i will be racing on a fast technical track, not an oval track |
Flat Servo Mounting
When mouting a servo flat on a 12th scale, what mounts are you using? And if your not using mounts, (hense using servo tape) when hitting a wall, is anybody expierencing the servo getting "tweaked" as a result of the hit?
Re: Flat Servo Mounting
Originally posted by acyrier When mouting a servo flat on a 12th scale, what mounts are you using? And if your not using mounts, (hense using servo tape) when hitting a wall, is anybody expierencing the servo getting "tweaked" as a result of the hit? I'm using the airtronics 94145 servo which has mounting ears for either mounting flat to chassis or regular angled servo mounts. |
Originally posted by Adam Hartzell You also need to make sure that the tierods are almost flat if you are looking at the car from the front. This will help to eliminate bumb steer. That could be your problem. I worked on that yesterday and will post pics shortly so you can see it. Thanks again. |
pics
I'll try to post the pics later today...
pics
here ar a couple of pics
http://home.satx.rr.com/rpena/images/IMG_1325.JPG http://home.satx.rr.com/rpena/images/IMG_1326.JPG let me know what you guys think.. |
Re: pics
Originally posted by picco007 here ar a couple of pics http://home.satx.rr.com/rpena/images/IMG_1325.JPG http://home.satx.rr.com/rpena/images/IMG_1326.JPG let me know what you guys think.. |
1 Attachment(s)
Originally posted by dontfeelcold i was told that there is not advantage between damper tubes and fricton plates, so i was wondering which one is easier to tune and which one is easier to maintain. is there any major differences between the major brands of 1/12's or are they all pretty much the same. i will be racing on a fast technical track, not an oval track Overall, the car is much better than the tube car and it improved laps about .4 to .5 seconds per laps, which was bout what 19t touric car was turing, I was .2 slower than the fastest 19t lap of the day. hope this helps. here is pic of CEFX body for anyone who wants to see it. It turns very well, but I am not completley sold on it yet. (about the HPI decals................its all I had LOL) |
rc12L3 and the rugrat conversion it is
your last post didnt pop up before i replied so might give that a go.
thanks for your help. |
ill probably get the rc12L3 and run as it is. Do IRS make a kit them selves or is it just optional parts?
Re: pics
Originally posted by dontfeelcold your last post didnt pop up before i replied so might give that a go. thanks for your help. I think some people are trying to get tom complex with these cars (save that for those TC cars LOL) |
it will be mod 4cells. might get the chassis, axle and diff rings too, we have to add weight to the cars so we might as well do it usefully.
your help is much apprecited. next question. bodyshells. should i get one i like the look of or are they another tuning option depending on what type of track you run on. |
Dontfeelthecold- Bodies are very important in 1/12 racing. I'm testing the CEFX body as we speak, but I would recommend the parma speed 8, which I'm about to switch back to. Good Luck
| All times are GMT -7. It is currently 04:29 AM. |
