Like Tree2991Likes
1/12 forum
Old 01-18-2004 | 10:54 AM
  #6151
Korey Harbke's Avatar
Default Re: yoke yrx 12 question
Originally posted by picco007
Does anyone know the reasoning for the big graphite brace the we have to slide the batteries under before we tape? I have found that to be annoying since it's cutting my shrink wrap on the top of the cells. Does anyone know? Can you cut those so the cells will not be under that brace?
I actually have another yokomo yrx-12 question. I tried using trc tires yesterday, but the left rear tires was rubbing the rear pod plate. My impression is the axle is a bit short. IS there any other reason this is hapening. I'm probably just going to buy an irs axle.
-Sushi Boy
Korey Harbke is offline
Old 01-18-2004 | 12:26 PM
  #6152
Default Re: Re: yoke yrx 12 question
-Sushi Boy
TRC tires are a bit wider than Jaco...the back spacing is different.
BrianJ is offline
Old 01-18-2004 | 01:55 PM
  #6153
I already tried the spacing part, I found it very strange.
-Sushi Boy
Old 01-18-2004 | 02:04 PM
  #6154
sean's Avatar
i had the same ploblem on my 10L3 touring. TRC tires (left tire) would rub on the pod. i have not tried them on my carpet knife yet.
sean is offline
Old 01-18-2004 | 02:06 PM
  #6155
sean's Avatar
question: for 1/12 stock racing do you think i would have an advantage running 1700mah ni-cads? run time is not an issue and the 1700's have much higher voltage.
sean is offline
  #6156
odpurple's Avatar
Default Tony M and Racenut
Tony-
The universal servo mounts that come with the CK might allow you to install a standard servo, but it's not a good idea. It will take up too much room and the extra weight up front won't help either. Save yer pennies and get a small servo. If money is the issue, the Hitec 225 MG can be had for only about $30 (or the plastic gear 225 for $5 less). It's not the best but it works.
John H-
I'm reading this on Sunday so it's too late to go to Hobbyworld. If I'd known there was a race, i'd be there (racing in the dark). Jeez, nobody tells me anything...
See you in Stockton-will you be wearing suspenders from now on?
O'D
odpurple is offline
Old 01-18-2004 | 03:34 PM
  #6157
Matt Howard's Avatar
You would be at a big disadvantage trying to run 1700's. The voltage is much higher with the GP's (remember they are now matched at 30 amps compared to the 20 amps your 1700's probably were matched at) and the internal resistance of the GP cells are much lower than the nicads ever were. Running the 1700's you will be lacking runtime, voltage, and punch
Matt Howard is offline
Old 01-18-2004 | 07:17 PM
  #6158
I just recived a my yokomo worlds and was wondering a good setup for running stock on carpet. The track is pretty tight with a medium lenght straight away. What tires, springs, and is this a good chassis it seems kinda thin. I really want to keep the chassis instead of getting a conversion for it.
Baboon14 or someting like that told me a setup once before but I cannot find it in the forums it was abuot a month ago or so. Also what body do you guys like to run.
Thanks in advance.
Sorry if I got your name wrong Baboon14
rcracer37 is offline
Old 01-18-2004 | 07:24 PM
  #6159
Thanks in advance.
I only used that chassis a couple times before I got a hyperdrive chassis. Here is my setup when I ran the Yokomo Chassis:
.22 springs up front, 10 deg caster, jaco purples
AE Blue spring in the back, thick tbar, mine had damper tubes and the damper disk setup (dunno why. I bought it used) so I put trinity purple stuff in the tubes. and Jaco Grey tires in the back.
Old 01-18-2004 | 08:07 PM
  #6160
Thanks Sushi Boy I appreciate the feed back I will try that.
Anybody use this setup or something different.
Thanks again.
Old 01-18-2004 | 08:11 PM
  #6161
For my yok I ran .20 in the front and the olive spring on the shock with the thick Tbar. I ran purples up front and white rears with the Cyrul body
Old 01-18-2004 | 08:16 PM
  #6162
Thanks Matt Howard, this is a great site I am glad I asked here the info I am getting is great.
and thanks once again guys
Old 01-18-2004 | 08:24 PM
  #6163
JimmyMac's Avatar
If you run TRC's on a 12L3 or Yok, you need to grind down the lower rear pod plate to allow clearance for the tire. TRC's are a different offset than Jaco's. Jaco's mount flush with the hub. TRC's are offset into the wheel alittle. That's why they rub on certain cars. My RugRat is slightly trimmed for this. Just get a dremel with sanding drum and go over the lower pod a couple passes til it clears. Simple, fast, easy. Just don't forget to go over it with superglue on a QTip to seal it back up.
As for Yok setup, I ran .020 springs (AE4113), thicker plate (or spring steel), Purple Front, Gray Rear, and Askari Body. 10° caster with shims to the back. 4 shims above upper arm, 2 shims under upper (kingpin). Batteries back with weight added on the rear tabs on the chassis (don't remember how much, but enough to get it at min weight). Slight toe out, with -1° ~ -1.5° camber. After that I went with a RugRat since I'll be at the Birds.
JimmyMac is offline
Old 01-18-2004 | 11:07 PM
  #6164
Thanks KilRuf This will at least get me going.
Old 01-18-2004 | 11:30 PM
  #6165
Yay, I fixed it. Thanks KilRuf, trimming it did the trick.
-Sushi Boy
