Like Tree2991Likes
1/12 forum
Old 01-06-2004 | 04:23 PM
  #5986
fast-ho-cars's Avatar
Default DELTA Spider 12th scale
check out ebay auction # 3168375293
it is was one of the final versions that Delta came out with.......no t-bar. yet it has fwd movement and side to side all bearing supported on shafts
fast-ho-cars is offline
Old 01-06-2004 | 04:40 PM
  #5987
Brian McGreevy's Avatar
DavidL,
Couldn't you have just raised the inner ballstud for the camber link to achieve a more horizontal link, and thus a lower roll center, which would give you more grip?
Brian McGreevy is offline
Old 01-06-2004 | 05:31 PM
  #5988
No, Brian, the entire assembly rotates on a hinge pin on each side so raising that link doesn't accomplish anything. This suspension has a hinge pin out near the C-Hub that holds the spindle. All other suspensions for RC cars have the pivot near the center of the car. That way an upper link can be added for proper geometry. Good geometry on this suspension for an upper link would result in a link that is about 1/8 inch long. That length would be almost impossible to build with robustness to survive racing.
davidl is offline
Old 01-06-2004 | 07:37 PM
  #5989
Corey Bernardo's Avatar
cheees David! Easy..............lol
Corey Bernardo is offline
Old 01-06-2004 | 08:07 PM
  #5990
Sorry david, it just looked as if that would accomplish something after looking over the front end...
Old 01-07-2004 | 06:09 AM
  #5991
stormperson's Avatar
Anyone here going to the January Jam at RC Madness in a couple weeks time?
I'll be there...
stormperson is offline
Old 01-07-2004 | 06:42 AM
  #5992
sean's Avatar
does anybody use a JR Racing z3550 steering servo in there 12L3? i am in the process of setting up my first 1/12 car and thats what i put in it. did i make a decent choice?i am new to 1/12 so i had to take the advice of my local hobby shop.
sean is offline
Old 01-07-2004 | 06:51 AM
  #5993
CypressMidWest's Avatar
It's a good servo, ran one for years before upgrading to the KO digital 947. You should be fine.
CypressMidWest is offline
Old 01-07-2004 | 07:04 AM
  #5994
ChrisP's Avatar
The JR 3550 is what most of the racers run at our local track. It's fast, centers well and is nice and compact.
MAKE SURE you run a good servo saver on it though, I'd also recommend carrying a spare gear set...just in case. The gear sets are just basic nylon and they're inexpensive...better safe than sorry.
I'm running a JR3550 myself and I BEAT THE CRAP out of it...and I haven't had any trouble...but I still have a spare gear set just in case
ChrisP is offline
Old 01-07-2004 | 07:10 AM
  #5995
sean's Avatar
one more question. the track i will be running on is about 100' x 50' with a few tight spots but relatively open. if i were to use a monster stock what kind of starting gear ratio should i use? i am not looking for top speeds, something to get used to the car with(never driven a 1/12 befor)i certainly dont want to over gear myself. oh and BTW will the Quantum Sport be o.k. for caual stock racing? i dont have time to really do it competitvly yet ,so i figured
i would start with the sport.
sean is offline
Old 01-07-2004 | 07:29 AM
  #5996
rayhuang's Avatar
Sean-you can never go wrong with a 1.79 to 1.89" rollout on a Monster on a track about what you described.
Just bring your tree of pinions and change pinions after 4 minutes of practice and go finish the pack with a different pinion. Do that a few times and you'll find a rollout that suits you.
Believe it or not-you can sometimes drive better with your car rolled out higher (more top speed-less punch). Car doesnt feel as punchy out of corners so it can be easier to drive. But gauge if youve rolled out too high by motor temp and runtime. If you dont have the batteries to be geared that high-you wont finish races strong.
Have fun,
Ray
rayhuang is offline
Old 01-07-2004 | 07:34 AM
  #5997
rayhuang's Avatar
Sean-heres some numbers for you:
2.00" tires 29/100 = 1.82 rollout
1.90" tires 31/100 = 1.84 rollout
1.80" tires 33/100 = 1.87 rollout
I just did this to show that as your tires wear-just go to bigger pinions and you can stay in the same ballpark on rollout. 2" tires are basically new out of package.
rayhuang is offline
  #5998
sean's Avatar
uh, i dont really understand roll out. i have always just figured my gear ratio by dividing my spur tooth count by my pinion tooth count. 100 spur-25 pinion= 4:1. how do i calculate roll out?
sean is offline
Old 01-07-2004 | 07:40 AM
  #5999
rayhuang's Avatar
Default Rollout
(tire diam x 3.14) x (pinion/spur) = rollout
Now-if you want to figure out what pinion to run to keep that rollout because your tires got smaller-then:
(rollout x spur) / (tire diam x 3.14) = pinion
rayhuang is offline
Old 01-07-2004 | 08:05 AM
  #6000
sean's Avatar
thank you for the explanation, that simple equation clears it up nicely
sean is offline
