Like Tree2991Likes
1/12 forum
Old 01-13-2020 | 11:31 AM
  #48121
silden's Avatar
BTW.
The DQ in A2 didn’t cost him the Worlds.
It was the move on Michael right after the start and the tangle up after. He should have stayed calm and pick up the spot later on. Marc checked out what he needed to get the title and stuck to the plan.
LonnyJ1950 and two shoes like this.
silden is offline
Old 01-13-2020 | 01:10 PM
  #48122
Originally Posted by SlotCarRacer
And it's tech you have to pass and I would imagine that the BRCA will have their test equipment tested and approved by an outside specialist given this was a Worlds event
​​​​​Dude.. i don't really give af, i was answering a question of why he didn't participate in the A2 main. Next time I'll scroll on thu
Racermac73 is offline
Old 01-13-2020 | 01:23 PM
  #48123
MarkBurgess's Avatar
Originally Posted by Racermac73
Boosted modified and nobody was close to dumping from what I've heard.. so i seriously doubt over charging was a advantage the way it is in blinky spec classes
You heard wrong!
I had the privilège of refereeing enough modified heats and finals at these Worlds. I saw at least a couple of racers dump before the 8 minutes. And there was a reason why the pole sitter chose not to run a warm up lap in the finals
silden and antlockyer like this.
MarkBurgess is offline
Old 01-13-2020 | 01:27 PM
  #48124
Originally Posted by MarkBurgess
You heard wrong!
​​​​​Dude.. i still don't really give af, i was answering a question of why he didn't participate in the A2 main. Next time I'll scroll on thu lol
Old 01-13-2020 | 01:34 PM
  #48125
Read Marc Rheinard post on Facebook between the A2 and A3 rounds. Base your information of what happened off of that.
1/8 IC Fan likes this.
Old 01-13-2020 | 01:54 PM
  #48126
Oleg Babich
Do you know how is the rear ride height adjusted?
Awesomatix 1/12 car has actually two ride heights on rear due to lack of single chassis where the single ride height can be measured.
The car's "chassis" consists of two big parts and every part has own ride height.
First ride height is the height under motor and is adjusted via shims under rear axle tube.
Second ride height is the height under rear end of battery and is adjusted via set screws in the long side bars near to the battery.
Oleg Babich is offline
Old 01-13-2020 | 02:04 PM
  #48127
RacinJ's Avatar
Oleg, Do you have additional photos of the car you can share with us?
RacinJ is offline
Old 01-13-2020 | 03:06 PM
  #48128
The car is in the state of some changes after WC now.
First prototype is here:
Old 01-13-2020 | 03:30 PM
  #48129
RacinJ's Avatar
Thank you for the post.
You stated earlier that the second ride height adjustment was accomplished with set screws in the long side bars near the battery, do they also adjust the roll stiffness of the car along with tweaking the chassis?
RacinJ is offline
Old 01-13-2020 | 03:33 PM
  #48130
Roll stiffness is adjusted via separate small coil springs that are not visible on the picture.
Old 01-13-2020 | 04:15 PM
  #48131
RacinJ's Avatar
Wow. It keeps getting more interesting. Thank you for sharing that.
RacinJ is offline
Old 01-13-2020 | 04:47 PM
  #48132
simple's Avatar
IF nothing else, it looks super cool!
LonnyJ1950 and Flygio like this.
simple is offline
Old 01-14-2020 | 12:53 AM
  #48133
antlockyer's Avatar
Originally Posted by Zerodefect
No idea if IFMAR does anything like that. 4.205 is an unacceptable ruling. That racer should have not been DQ'd until 4.21.
4.205 would have been ok, as would 4.209, the rule was 4.20, first time it happens you got a warning, second time you weren't allowed to take part in that run. In case anyone is interested I was doing about 5800mah a run, I was using very little brakes.
antlockyer is offline
Old 01-14-2020 | 02:08 AM
  #48134
josecarlo1129's Avatar
Oleg, you know that I am a big fan of your cars since the beginning! Now take my money, I want one!
Oleg Babich likes this.
josecarlo1129 is offline
Old 01-14-2020 | 03:11 AM
  #48135
Do you have any idea when it will be available for sale?
SlotCarRacer is offline
