question...how often are you guys swapping out springs?
Going over my notes I found myself changing them once a season or if they are different in height.
Originally Posted by phatboislim
(Post 15381161)
you should try to match the length to prevent any uneven roll. |
One thing about truing tires that I learned recently, if you cut the edge of your tires on a 45 degree bevel all the way to the plastic of the rim as opposed to rounded or vertical it gives a better feel. I tried this on both fronts and rears and the car was noticeable more forgiving.
(Post 15381159)
i personally glue then true. otherwise my glue job would look like turd pebbles
https://cimg4.ibsrv.net/gimg/www.rct...5f14f7c37f.jpg |
Originally Posted by AngryRog
(Post 15381103)
Are you gluing and then truing to size? Running the tire square edged or rounding after glue?
Cut then glue takes a lot of skill. You need to test the edge to ensure it's hard everywhere Wish this was easier |
I have the best luck when cutting twice. If I want tires to be 40mm then I cut around 40.3, glue, cut to 40. Glue stays good with a nice edge. When I glue and make 1 thick cut half the glue flakes off.
Originally Posted by hanulec
(Post 15381514)
Glue then cut is hard as if glue chips off what do you do? Or how do you re-glue tires
Originally Posted by DesertRat
(Post 15381460)
I never have good luck when I glue then true. Always end up chunking the tire when glue chips off. Perfer to true, round edge, then glue using the BSI medium CA In the green bottle. That wirh a nice fine point metal tip works great for me. Might have to try the 45° bevel on my next set of Mod tires. |
(Post 15381460)
Any others have experience with the 45° bevel method? |
Originally Posted by VanBee
(Post 15381805)
This method interests me. I still race on grey carpet but have had experience with the black carpet glue requirement. I did not enjoy it and kept thinking there HAS to be a better way!
(Post 15381839)
I still glued the sidewalls on the fronts.
Originally Posted by silden
(Post 15381328)
I usually swap the spring when they have sag to much like 0.5 mm differents between left and right. you should try to match the length to prevent any uneven roll.
Originally Posted by Hopscotch
(Post 15381251)
Originally Posted by iTz Nicholas72
(Post 15381685)
(Post 15381852)
So you 45° beveled the fronts and the backs?
| All times are GMT -7. It is currently 03:39 AM. |
