So I am getting a lot of chassis rub when running mod 12th. This is with 10k tube lube running a whole host of different side springs.
Is this something that is fairly common with mod 12th on a fairly technical track, or should I try addressing it with thicker tube lube? I have only ran mod on very flowing layouts before with very few abrupt direction changes and chicanes, so I am in unfamiliar territory with our current layout. I am also concerned about making the car too edgy and burning through rear traction if I use thicker tube lube, since our carpet is medium traction at best with our normal practice and racing. Car is a CEFX, currently using 10k tube lube, SM linear side springs just touching. Any ideas? |
Edit: Wrong thread.
Originally Posted by LloydLoar
(Post 11623191)
Originally Posted by DesertRat
(Post 11623869)
A stiffer center shock spring will do a better job of holding the momentun change, while stiffer springs usually do mean more steering, when my car was dragging and diffing out it gave me a much better overall traction. If the change of center spring loosens the back end too much, try increasing the angle of the center shock with the old spring to make it more progressive.
With that said, do you think a center spring change could help with chassis rub on the side edges as well? I don't think I am getting any rub from the car squatting or lifting during momentum changes; it just seems to have a lot of roll. |
(Post 11623948)
I should have been more specific. I am not actually getting any chassis rub on the middle of the chassis. Most of the chassis rub is on the protrusions where the front pivot balls are mounted for the sidelinks, as well as on the back corners of the main chassis plate (by where the crossbrace posts are mounted). This is why most of my focus has been on tube lube and side springs.
(Post 11623974)
Lloyd, I figured you meant the sides where the pivots are, and probably dragging the side of the pod at the link mounting point as well. In order for either point to drag, the center spring has to compress a long way as the front roll is quite stiff. I think a stiffer center spring will help you out if you don't want to go to heavier side fluid and changing side springs didn't help.
I have also found that in situations where changing side springs doesn't result in any changes to handling, lap times, roll, etc, it typically will mean that my tube lube isn't the right thickness. As such, I might try pulling off one of the tubes just to see what the car does. Josh typically says that 15k is the most you can run in the tubes with mod before worrying about losing the rear end, so I have a little bit of wiggle room if I need to go stiffer (although I am no Josh, so I am not even sure if 15k will work for me). Thanks! |
I'm driving a link car with an old school front end, and am chasing more steering at the exits of corners. Corner entry steering is quite sharp, and the mid-corner is ok. What change can I make that will target steering at the corner exit? Should I investigate ackerman or bump-steer changes?
I have an FTM FTR 12, that I purchased a few years back but never fully built, kids etc.. I sold my T2 so now I need to build this to have something to play with.
I'm looking to get out a few times this year and wanted to finish off the car <battery, esc, motor>. I will run stock class and am partial to novak. What is the roar legal novak esc and motor that will fit this car? Also the car has the tbar running through the middle, what kind of battery fits the car now that everything is lipo? please only mention roar approved. |
Originally Posted by butrflynlambie
(Post 11633763)
I'm looking to get out a few times this year and wanted to finish off the car <battery, esc, motor>. I will run stock class and am partial to novak. What is the roar legal novak esc and motor that will fit this car? Also the car has the tbar running through the middle, what kind of battery fits the car now that everything is lipo? please only mention roar approved. James |
Originally Posted by Bikerbob
(Post 11633787)
There used to be a saddle pack - look back through the thread. I think they said they would make a 1 off if you needed it. But that or run Nimh cells is your only choice. I think the saddle was ROAR when it was made.
James Novak dedicated 1S ESCs that are on the ROAR Approved no timing list are: NOV1731 Novak Havoc 1 Cell NOV1741 Kinetic 1S Racing Brushless ESC NOV1743 OVAL SPEC 1S Brushless ESC Assuming you are in the US, and are therefore interested in either 13.5 blinky or 17.5 blinky, motors: 13.5 Novak 3413SS 13.5 Novak Ballistic 3613 17.5 Novak Ballistic 3617 17.5 Novak 3417 SS 17.5 Pro |
Originally Posted by Radio Active
(Post 11633962)
It was the Speedzone 5200mAh 1S Saddle (SZ5200PROSD1S). A Speedzone rep was asking to see if there was interest from enough people to get it re-released not so long ago.
Novak dedicated 1S ESCs that are on the ROAR Approved no timing list are: NOV1731 Novak Havoc 1 Cell NOV1741 Kinetic 1S Racing Brushless ESC NOV1743 OVAL SPEC 1S Brushless ESC Assuming you are in the US, and are therefore interested in either 13.5 blinky or 17.5 blinky, motors: 13.5 Novak 3413SS 13.5 Novak Ballistic 3613 17.5 Novak Ballistic 3617 17.5 Novak 3417 SS 17.5 Pro Thanks for the help. All three ESCs listed are on Novak's discontinued list.. Ugghhh... |
(Post 11634397)
http://www.ebay.com.au/itm/140899747...#ht_2861wt_952 http://www.ebay.com.au/itm/290731959...ht_3037wt_1139 |
If you get one you might need a booster too...As I recall the Novaks don't have one built in.
Originally Posted by InspGadgt
(Post 11634433)
Get the Novak Impact Racing Brushless ESC with X-Drive and a Booster NOV5477 with Glitch Buster NOV5626.
I'm guessing you might have to cut the heat sink down so that it will fit under the body. |
| All times are GMT -7. It is currently 04:00 AM. |
