Like Tree2991Likes
1/12 forum
Old 03-28-2011 | 01:42 AM
  #35671
PizzaDude's Avatar
Chris,
The design in the top pic, is pretty tricky to setup.
As you probably allready knew.
I found, that when running on carpet, the old(er) skool front beam front end will work better and is way easier to setup.
I know, I know...not to many setup options but when running it for a while, the laptimes are flatter and the end result faster.
Maybe another thing to try in the future
PizzaDude is offline
Old 03-28-2011 | 03:09 AM
  #35672
wingracer's Avatar
Originally Posted by SlideMasteR
Hi guys
haven't run 12th in a while and staring again and am a little lost as to where i should start in terms of roll outs, could anyone help with a roll out for boosted 10.5 on large asphalt track with fairly technical but flowing infield running 1s ?
tx in advance
Start around 60mm. I like about 67 but you have to run less boost to pull it. Lap times are better for it though.
wingracer is offline
Old 03-28-2011 | 03:25 AM
  #35673
SlideMasteR's Avatar
Wow 60 mm damn ok ! Tx will take this info over to the tekin thread and see what settings the guys suggest
SlideMasteR is offline
Old 03-28-2011 | 07:26 PM
  #35674
CypressMidWest's Avatar
Originally Posted by RacinJ
Sorry Mikey. I registered with the RCChat website over a year ago and didn't have any issues. Not sure what may be the issue.
Props on the avatar RacinJ. That's my favorite race car EVER....
CypressMidWest is offline
Old 03-28-2011 | 08:04 PM
  #35675
Ian,
Grand Finale at The Gate this weekend, should be a good one.
chuck
mackin is offline
Old 03-28-2011 | 09:14 PM
  #35676
Originally Posted by mackin
Ian,
chuck
Dad and I are working out the details. Looking about 90% sure right now Chuck.......
Old 03-29-2011 | 04:01 AM
  #35677
VooDooPH's Avatar
Ran my R12 with a HW 1S the other day (4.0T comp2 SP motor)... was geared to a 37mm roll-out (88/24, 43mm wheels). 119_MOD FW was tuned down (DRRS =1, no boot, no timing). Kit ran well and was plenty quick... however, after running the car for about 5mins, the ESC was hot to the touch (no heatsink and fan due to the low bodyshell). The motor was warm but i could hold my finger on it without getting burned....
just want to know if i'm over geared or under geared? or is it normal to have the esc run very hot (wasn't able to temp it though).
Any help would be appreciated.
thanks!
VooDooPH is offline
Old 03-29-2011 | 05:18 AM
  #35678
andrewdoherty's Avatar
thanks!
I have only run about 5 or 6 packs in a mod 12th recently, but hot esc and cooler motor has been my experience too with an RS Pro.
andrewdoherty is offline
Old 03-29-2011 | 05:40 AM
  #35679
thanks!
I usually run 96/23
sdunnmcp is offline
Old 03-29-2011 | 07:00 AM
  #35680
RedBullFiXX's Avatar
thanks!
My 12R5 has a MurfDogg 4t with a Tekin RS (not RS Pro) at 42 roll in Dual Mode.
Endbell at zero deg.
Motor and esc after 8mins never over 100f
Tekin internal temp light at 1st mark.
It is very smooth and has tons of rip.
This is on Hi-Bite carpet 90x45 track.
RedBullFiXX is offline
Old 03-29-2011 | 07:07 AM
  #35681
Ian, Hope you and your dad can make it. Want to talk to you about The Halloween Classic and The Indoor Champs.
chuck
mackin is offline
Old 03-29-2011 | 07:19 AM
  #35682
VooDooPH's Avatar
Originally Posted by sdunnmcp
I usually run 96/23
Thanks for the feedback.
Andrew, what RO are you using?
here's a vid of the track we play at... not quite sure how long the back straight is... maybe 40ft?
http://www.youtube.com/watch?v=LLGzU4eZnFM
also, i assume you guys are running rx packs with your RS'... care to show pix on how its wired?
Thanks!
VooDooPH is offline
Old 03-29-2011 | 10:22 AM
  #35683
Thanks!
I'm still running the same RS & TQ Booster since I built the car new about 2 yrs ago.
Works great.
Old 03-29-2011 | 11:48 AM
  #35684
avs's Avatar
avs
hey Dave, is that with 1 or 2 caps installed?
avs is offline
Old 03-29-2011 | 12:40 PM
  #35685
I haven't put the 2nd cap on yet, i will try and get that installed this week.
