Like Tree2991Likes
1/12 forum
Old 07-14-2010 | 07:21 AM
  #34051
wingracer's Avatar
Originally Posted by Dragonfire
Have many people here had much experience with the Exceed foams? How do they compare to other tires you have run (on carpet or asphalt)?
Just go back one page.
This exact same question gets asked every other day it seems.
wingracer is offline
Old 07-14-2010 | 03:23 PM
  #34052
hairymuffin's Avatar
Not sure if this helps? Pretty cool though
Attached Thumbnails 1/12 forum-10th_foam_10.gif
hairymuffin is offline
Old 07-14-2010 | 08:59 PM
  #34053
I just bought the Xray xii link is there any parts that i need to get right off or any parts to help tune the car.
chadb is offline
Old 07-14-2010 | 09:17 PM
  #34054
PDX-Spike's Avatar
There's an XII forum on the Xray website. Good place to start.
PDX-Spike is offline
Old 07-15-2010 | 12:46 AM
  #34055
Drillit's Avatar
From: Oreganastan Pacific Wonderland home to Indoor Farming
Hey Roger, what if a guy had a T-bar Xray.......oh wait, its a 10th scale, never mind.......\_______/ \___
................\_T_____\
Drillit is offline
Old 07-15-2010 | 09:25 AM
  #34056
PDX-Spike's Avatar
You must be confused...again. The XII cars are 12th scale and the XIO cars are 10th scale. There's a link and T-bar version in each.
The post I replied to was related to the XII car.
Old 07-15-2010 | 10:13 AM
  #34057
And i just bought the Corally 12SL.
After being disappointed with the quality of the Serpent S120 Link ...
Greetz,
C.
CivicTuning is offline
Old 07-15-2010 | 10:18 AM
  #34058
wow really care to explain
motojon is offline
Old 07-15-2010 | 11:17 AM
  #34059
YR4Dude's Avatar
Greetz,
C.
Biased comment from a Corally fan.
Same could be said about a Corally after buying a Serpent.
YR4Dude is offline
Old 07-15-2010 | 11:47 AM
  #34060
No he doesn't. You know full well the internet was built for people to make baseless allegations! That's why it's called the World Wide Web (of deceit). The bit in parenthesis is usually left out
JR007 is offline
Old 07-15-2010 | 12:13 PM
  #34061
After having bought at least 6 Serpent cars, the last 2 have been disappointing in build quality, pieces really don't fit unless you alter all sorts of stuff.
And that is unacceptable to me.
Not to mention some pieces being twice in the kit and other pieces aren't, etc etc. Got fed up with it and bought something else, a Corally.
We'll see how that goes, build quality is better up until now.
Greetz,
Christoph
Old 07-15-2010 | 01:18 PM
  #34062
I ran the Serpent front end on my BMI for awhile. Overall the quality was very good...the machining and molding looked good with no abnormalities. Where I did have a problem was in slop...the upper arm has quite a bit of slop on the hinge pin. Also 1 of the 8/32nds adapters was not threaded all the way through. All in all though not near as much fiddling was needed to get the front end up and running as I have needed on other front ends.
InspGadgt is offline
Old 07-15-2010 | 01:32 PM
  #34063
Greetz,
Christoph
alright..... just curious
motojon is offline
Old 07-15-2010 | 01:34 PM
  #34064
yeah i hear you i had to switch to associated balls in the lower arms so i wouldnt have to modify the kingpins, simple swap though
motojon is offline
Old 07-15-2010 | 07:35 PM
  #34065
Default xceed tires
the tires are great...i ran them tonight on our track(med to high bite carpet)..they are easy ...only 3 types..i ran med up front and soft in the rear...the car was stuck to the ground...cut my lap times .3 ...were consistent the entire run and then some (12min)...this is my new tire..no need to worry about choosing colors anymore...
obi wun is offline
