Originally Posted by georgec
(Post 6851531)
RC4Less also makes natural rubber tyres :nod:
I'm looking at getting into 1/12 onroad after racing oval pancars for the last 5 years. Trying to figure out what I need to get, right now it's between the Associated 12R5.1 and the CRC Gen XL. I'm going to start out in the 17.5 Single Cell class, so any advice on gearing, tires, cars, and bodies would be appreciated.
Thanks in advance Michael |
Originally Posted by TommyBlazin
(Post 6851521)
U HAVE IT IN STOCK??? THEY ARE OUT ALREADY??
http://rcmarket.com.hk/product_info....oducts_id=7887 |
THAT BATTERY CALLS FOR CHARGING IN A 2CELL MODE AT 10.6 AMPS? is that safe? and would that icharger u sell there be able to do that. i currentlly use the cheap ice charger, as im new to lipo, time to step it up now...
(Post 6852380)
Spur/pinion
I'll be running LRP SXX
Spur/Pinion
Originally Posted by PDX-Spike
(Post 6851308)
Depends on which ESC you have! When I downloaded the new Tekin RS software, I dropped 8 teeth on my pinion, after increasing my spur by 12 teeth! (was 72/44, now 84/36)! That's on a 100 x 60 track.
(Post 6852380)
Originally Posted by pakk
(Post 6850801)
Has anyone had any problems running a 2cell lipo pack(8.4v) to futaba servos?
If you already have the pack, then consider a regulator if you have any problems. There doesn't seem to be any rhyme or reason why some people have no problems, and others do. HTH :) |
Originally Posted by oeoeo327
(Post 6852884)
The Ice charger won't have a problem with the 5300 battery - the 2C rating means that it can be charged safely at charging rates up to 10.6 amps. However, you must set the charging profile for 3.7 volts, not 7.4; otherwise, your new battery will never see the track.
(Post 6852969)
OK,SO WITH THE ICE I CAN SET IT AT 2C and get the 10.6...but again setting at 3.7 volts...what does this do charges faster? better performance as well?
Don't try to trick the ICE just to charge a little bit faster, or you'll smoke your 1s pack. |
The Ice charger can be set to charge @ rates up to and including 8 amps, but the recommended charging rate for a 5300 MaH pack is 5.3 amps.:nod:
(Post 6853016)
The only gain you'll see might be more track time due to decreased charging times. However, the downside is a decrease in the pack's lifespan. There are no performance gains associated with increased charging rates.
(Post 6853059)
Cool thanks, you just saved me some money on a new charger, and a possible smoked pack, ive been playing it safe doing the 4.9 charge rate with the older 4900 mah with no problems, just after seeing that wanted to make sure i was up to speed, but after your guys help, i see no reason to do it. THANKS GUYS!!! |
| All times are GMT -7. It is currently 05:01 AM. |
