Like Tree2991Likes
1/12 forum
Old 01-09-2010 | 07:42 PM
  #33136
CypressMidWest's Avatar
Originally Posted by wingracer
To me, the Parma and Jaco tires/wheels seem to be identical except the Parma front wheels seem to be even looser in the bearings than the Jacos. I have had both peel.
The best thing I have found to reduce peeling is after truing, hit the outside edge with a tire file to make sure no rubber overhangs the wheel and then really round off that edge. Then glue the bead with thin CA. They can still peel but it helps.
Awesome advice for ANY brand of foam tire.
CypressMidWest is offline
Old 01-09-2010 | 08:43 PM
  #33137
Originally Posted by CypressMidWest
Which rims frt or rr are you breaking and at what spot on the wheel? I think I've only broken two wheels in several seasons of running the CRC wheels.....
I cracked nearly every front rim I ran on carpet at last year's Snowbirds...they still ran pretty good even cracked though. I was pretty rough on the car though so my results may not be typical.
InspGadgt is offline
Old 01-09-2010 | 10:06 PM
  #33138
andrewdoherty's Avatar
Mostly fronts. The difference for me has been where the Jaco wheels may bend a tab shape in a hard hit, the CRC cracks. Sometimes all the way from inside to outside. I also broke two rears. One I am not sure exactly how it happened as I didn't notice it till I brought the car in after a race, and the other sheared off the 2 aluminum screws brushing next to a board on the straight. Half of the wheel was attached to the wheel and the other half passed the car. These were my first two pairs of CRC's, but I have seen similar failures from some others that tried them at our track. I've not ever broken a Jaco rear wheel in the 2+ years I've used them. Our LHS ordered the CRC's as tehy aren't able to get the Jaco's at the moment. Something to do with a fire at one of the facilities involved in making the wheels? Were wondering if Jaco will have to replace the molds if this is true. Might mean the bearing issue gets fixed . . .? I do love how the bearings fit in the CRC front wheels!
andrewdoherty is offline
Old 01-10-2010 | 12:32 AM
  #33139
What I wouldn't give for a 38mm version of the old black composite Jaco rims...those were very tough rims and didn't degrade when remounting foam.
Old 01-10-2010 | 02:52 AM
  #33140
Those bodies actually pre-date the HPI buyout of the original Hot Bodies company, based out of New Jersey. They Mark 2 is the HB Toyota GT-1, very similar in handling to the Protoform Nissan P-35, The Mark 3 is the HB Nissan NPT '91 which handled similarly to the Associated Nissan NPT body. Compared to the modern Proto, Parma, and Black ART bodies the HB shells would be lacking in downforce.
Hi!
Maybe I will get some luck from Master and my AMR's bodies arrive to me
before race.
However, with mark 3 car should drive, it must
Regards!
m.
M.Abramowicz is offline
Old 01-10-2010 | 08:32 AM
  #33141
Originally Posted by andrewdoherty
Does this information sound right to y'all?
Parma and Jaco use the same wheel and the same foam to produce their 12th scale foam tires.
CRC uses their own wheel and a different manufacturer of foam. Some call this GRP foam, from Italy.
Are there any other companies to use the same foam as CRC, but mounted to a different rim?
I ask because I'm tired of the foam on the Jaco and param wheels peeling back. I can run a clean race and come back the edges are peeled. I tried CRC foams and ran them several times. I had several wrecks, board taps etc, and when all was said and done there was no peeling. he only problem was the wheels were more brittle and most broke before I could wear the foam down. I've never broken a Jaco rear wheel.
I'm basically looking to get the foam I like (CRC, or GRP?) on a durable wheel. Thanks for any help.
AWD
PS- If wanted to remove old foam from a rim, which solvent would you think would remove the foam from the wheel best? lol, you know where I am going with this.
If you haven't tried the yellow wheeled TRC tires, you might try a few sets. They are the smaller diameter wheel, but the tire is made for TRC by GRP. The same compounds have the same characteristics when compared to CRC. You get the wheel that is like a Jaco and the more durable sidewall like the CRC. If you true tires anyway, the smaller size works great. I use 44mm rears and 42mm fronts. On the rears, the "Granite" is the same as a CRC Grey-Low.
Here are some steps I used when I ran Jaco's in the past. I think the problem is a substandard adhesive used to mount the foam.
1) peel up the outside edge right out of the box (5-7mm wide).
2) apply 3M weatherstrip adhesive with a small screwdriver or scrap lexan.
3) massage the edge to get full contact.
4) after it cures, super glue the rim seam and sidewall.
5) shape the sidewall on a truer. I go for a 15* angle back from the rim and then liberally radius the shoulder of the tire.
Frankly, Jaco's are a pain in the @$$. This seems like a lot of work, but we don't have those damn brushed motors and round cells to maintain anymore do we?
I do steps 4 and 5 from above on every set of tires I run. Consistency pays off at some point? Or, it should, I think?
Aaron
VRacing is offline
Old 01-10-2010 | 08:41 AM
  #33142
jkirkwood's Avatar
Where do you get TRC Tires now?
jkirkwood is offline
Old 01-10-2010 | 08:46 AM
  #33143
whynot's Avatar
Does anyone know if serpent will have 12 scale tires for there 12 scale? if so will they fit other cars?
mike
whynot is offline
Old 01-10-2010 | 09:44 AM
  #33144
Chemical X's Avatar
Originally Posted by M.Abramowicz
Hi!
before race.
Regards!
m.
I ran the mark 3 body before and it was stable and felt the same as a Speed 12 (at least to me). However, it was about 0.1 to 0.2 sec per lap slower than the Speed 12.
Chemical X is offline
Old 01-10-2010 | 09:48 AM
  #33145
wingracer's Avatar
mike
They already do. The ones I bought were Xceed/Jaco prizm so yes, they fit everything.
wingracer is offline
Old 01-10-2010 | 10:09 AM
  #33146
Chemical X's Avatar
There are these ones too in a Serpent package. But just like others... They are Jaco Prisms.
Attached Thumbnails 1/12 forum-serpent-12th-scale-wheels.jpg
Old 01-10-2010 | 10:10 AM
  #33147
Harder to find. I have bought them by the case when I track them down, often on RC-Tech or Ebay.
A few other sources listed below. If you go with the "new" style GRP tire, they are now made in the larger diameter size. Same durability as the smaller yellow wheel.
You will find several runs of tires that come from GRP and are the same product. GRP/TRC/Speedmind.
Try some out. If they work for you, buy in bulk as they are harder to track down on short notice.
These are the same tire, produced by GRP and would run the same as a TRC tire
http://www.rcmart.com/catalog/tire-w...facturers_id=0
http://www.the-border.com/product.ph...9&bestseller=Y
http://www.stormerhobbies.com/cgi-bi...umb=on&smode=0
VRacing is offline
Old 01-10-2010 | 10:31 AM
  #33148
RC MARKET's Avatar
New SMC 50C+ 5300mAh this week release !
RC MARKET is offline
Old 01-10-2010 | 12:12 PM
  #33149
There was a fire early last year destroyed the GRP factory in Italy. Since then, there have been no GRP 12th tyres seen in Europe. Although you may find some secondhand, all the new 12th tyres these days come from Jaco - Jaco Prism, Parma Blackhawk, Mobgums - except those from Gekko, BSR and RC4Less. HTH
SlowerOne is offline
Old 01-10-2010 | 02:03 PM
  #33150
TrevCoult's Avatar
Not forgetting Calandra Racing Concepts Pete!
Trev
TrevCoult is offline
