Like Tree2991Likes
1/12 forum
Old 06-14-2009 | 05:11 PM
  #31606
wingracer's Avatar
Originally Posted by isuzuguy
hey guys need sme advise on parma tires ,i can't find info on there tires as far as what works on carpet,what works on asphalt .in stock and 19t. jaco give you some info on each color so you can make a choice. parma ?
The new black wheeled Parmas ARE Jacos.
For carpet I usually run magentas all around. Sometimes yellow rears. I don't run asphalt but I suspect magentas or maybe pink rears will work great.
wingracer is offline
Old 06-14-2009 | 08:14 PM
  #31607
trailranger's Avatar
Originally Posted by hanulec
hi all - i know prs makes a 72T 64p spur. does anyone make one smaller? thx
PRS also makes 64, 65 spurs. You can thank the 21.5 Oval racers for those gears. www.LeftHander-rc.com carries PRS.
trailranger is offline
Old 06-14-2009 | 08:21 PM
  #31608
theisgroup's Avatar
are you sure? i see 65 pinions, not spurs. if they do, you would have to use a stealth diff and not the current big ring diff
theisgroup is offline
Old 06-14-2009 | 10:29 PM
  #31609
CarlosG.'s Avatar
Does anybody know what profile setting I should run the Novak 4-Cell for 1s LiPo? I am switching over and would greatly appreciate any information on this.
CarlosG. is offline
Old 06-15-2009 | 02:57 AM
  #31610
The machined Robinson spurs go as low as 68...used to run that in my F201.
InspGadgt is offline
Old 06-15-2009 | 07:21 AM
  #31611
andrewdoherty's Avatar
Is that 64 or 48 pitch though . . ?
andrewdoherty is offline
Old 06-15-2009 | 07:46 AM
  #31612
theisgroup's Avatar
smallest they list on their site is a 73 n 64pitch. i see a 60 in 48
Old 06-15-2009 | 04:08 PM
  #31613
I see they only show 1 line of spur gears now. They used to sell 2 lines of spurs so it is likely the 68t 64p spur I had was from the discontinued line.
Old 06-17-2009 | 12:15 PM
  #31614
ds400's Avatar
Default setup
Hey guys, got a XII and races on a high speed track on asphalt. I need help on car setup so your help would be awesome.
What does rebound on the central shock change in the car behaves?
I am running 100% rebound atm.
Here is my track
http://www.crccc.co.nz/MyImages/SCAN3303_000.pdf
Didier
ds400 is offline
Old 06-20-2009 | 07:56 PM
  #31615
BigPapa's Avatar
Thumbs up 1/12 xray
I am running rebound 35% , and ride hight 4.0 in the front and 4.2 rear, central shock oil trinity 42.5. pod damping 8.000, droop .8 gear 78/45 trinity duo 10.5 0 timeing 1.65 front r1.75 double pink front. pink rear
Here is my track
Didier
BigPapa is offline
Old 06-24-2009 | 07:51 AM
  #31616
rinkrat99's Avatar
Default Ride Height Gen -X Front End
Hi all
For those of you running the CRC Gen-X Front End, what is the minimum tire diameter you can run with the 3 mm Ride Height Spacer used? Can I run the arms with the #4262 - Precision Front Ride Height Adjusters?
Any ideas?
rinkrat99 is offline
Old 06-24-2009 | 08:06 AM
  #31617
Casper's Avatar
Yes you can use the precision ride height adjusters. I would say you could go down to the rims but not sure how low you can run your car at your track. I am using the 4's with some cut down tires and my ride height is between 4-4.5 so I feel pretty confident you could get all the ride height you need with the blocks for gross changes and the precision adjusters for fine tuning.
Casper is offline
Old 06-24-2009 | 08:29 AM
  #31618
This maybe a stupid question. But what is the best way to determine where to drill your holes on a body that's been painted? I've got one that I'd like to mount up. But I want to make sure the holes are pretty darn close. Any advice? I know I've done it in the past. Just looking for maybe an eaiser way. Thanks.
SwampDog32 is offline
Old 06-24-2009 | 08:35 AM
  #31619
Casper's Avatar
You can use a little bit of paint to do this. Put some wet paint on the body posts and then carefuly line up the body on the car and push down. The wet paint will transfer dots on the body where to drill. You can use a marker as well but the ink will dry much faster.
White out would work well for this as well.
I marked the body posts on the clear body first. Used a sharpie and marked the overspray film. Even if the body does not have over spray film you will be drilling out the markes or you can get sharpie off lexan with rubbing alcohol.
Casper is offline
Old 06-24-2009 | 08:44 AM
  #31620
Juan C Munoz's Avatar
Default Setup Trouble
Is there any guide on how to setup the Serpent S120 ?
I'm new at Electric On-Road cars and having real trouble finding the right setup for my car. I was hoping if you guys can direct me to a guide that explains to me the trick to setup my car for any track.
Juan C Munoz is offline
