Like Tree2991Likes
1/12 forum
Old 12-19-2008 | 07:45 PM
  #29956
andrewdoherty's Avatar
Not a knock, just looking for facts. . .
isn't the splicing of the 16 gauge wire pointless with the 18 gauge connected to it? Does the " A chain is only as strong as its weakest link" apply here?
I'm thinking of doing this to a car, but if there's no advantage to the splice I will leave that step out and run 18 gauge all the way from the esc to the motor.
andrewdoherty is offline
Old 12-19-2008 | 07:54 PM
  #29957
Ike's Avatar
Ike
Must............
Own...............
Page.......
1000!
Ike is offline
Old 12-19-2008 | 07:55 PM
  #29958
Ike's Avatar
Ike
Bah!
I suck at the inernet!
Ike is offline
Old 12-19-2008 | 07:58 PM
  #29959
RCSteve93's Avatar
I believe he removed the insulation and put a coat of shrink wrap to thin the wire for under the batteries. That is not a splice.
Insp Gadgt did that wiring job.
RCSteve93 is offline
Old 12-19-2008 | 07:59 PM
  #29960
W.E.D.Jim's Avatar
How many posts before we get to page 1000?
...Jim
W.E.D.
W.E.D.Jim is offline
Old 12-19-2008 | 08:01 PM
  #29961
W.E.D.Jim's Avatar
...Jim
W.E.D.
Old 12-19-2008 | 08:02 PM
  #29962
Ike's Avatar
Ike
...Jim
W.E.D.
Good Question!
Ike is offline
  #29963
CarlosG.'s Avatar
I would think the way the wires are curved up by the motor would limit the movement of the rear pod.
Just trying to get that 1000th page.
CarlosG. is offline
  #29964
Trips's Avatar
Actually, the important wires for power delivery are from the battery + terminal to the motor + terminal, and from the motor - terminal to the esc - terminal. When you splice a wire onto the batt+ to motor + wore to go to the speedo +, it can be ANY piece of wire. I've even used 22 ga. servo lead there. The wire from the batt + to the esc+ powers the ESC only, it does not deliver any power to the motor.
I see a LOT of guys run the + lead from the ESC to the motor, then splice a piece of wire to that to go to the batt + terminal. This is backwards... they're putting another solder joint in the power path.
The way ALL brushed ESC's work is on the negative side, power to the motor should ba a straight path from batt+ to the motor +.
Hope that makes sense...
Trips is offline
Old 12-19-2008 | 08:03 PM
  #29965
Ike's Avatar
Ike
...Jim
W.E.D.
Nice body!
Never thought I'd say that to a dude...
Ike is offline
Old 12-19-2008 | 08:04 PM
  #29966
Genius! Thanks for the insight . . .
Old 12-19-2008 | 08:06 PM
  #29967
Ike's Avatar
Ike
Perhaps 999 just lasts forvever
and ever...
Oh wait...
It's all mine, muahaha!
Ok, back to some meaningful posts...
Ike is offline
Old 12-19-2008 | 08:10 PM
  #29968
Trips's Avatar
oops... I just went and looked at the picture you referred to, and I see my answer in my previous post doesn't apply to your question...
RcSteve's answer a few posts back is correct... those aren't splices, he stripped the silicone insulation and replaced it with heat shrink to make it thinner.
Trips is offline
Old 12-19-2008 | 09:28 PM
  #29969
odpurple's Avatar
That's right, its a way to fit 3 wires under the batteries. There is only one brand of wire that will do that without stripping and shrinkwrapping, that's the 16ga from Castle Creations, but it is too stiff and wicks solder too much for my liking
odpurple is offline
Old 12-19-2008 | 09:29 PM
  #29970
odpurple's Avatar
Ike wins!
...something
odpurple is offline
