isn't the splicing of the 16 gauge wire pointless with the 18 gauge connected to it? Does the " A chain is only as strong as its weakest link" apply here? I'm thinking of doing this to a car, but if there's no advantage to the splice I will leave that step out and run 18 gauge all the way from the esc to the motor. |
Must............
Own............... Page....... 1000! |
Bah!
I suck at the inernet! :cry: |
Originally Posted by andrewdoherty
(Post 5188269)
Not a knock, just looking for facts. . .
isn't the splicing of the 16 gauge wire pointless with the 18 gauge connected to it? Does the " A chain is only as strong as its weakest link" apply here? I'm thinking of doing this to a car, but if there's no advantage to the splice I will leave that step out and run 18 gauge all the way from the esc to the motor. Insp Gadgt did that wiring job. |
How many posts before we get to page 1000?
...Jim W.E.D. |
Originally Posted by W.E.D.Jim
(Post 5188309)
...Jim W.E.D. Good Question! |
I would think the way the wires are curved up by the motor would limit the movement of the rear pod.
Just trying to get that 1000th page. |
(Post 5188269)
isn't the splicing of the 16 gauge wire pointless with the 18 gauge connected to it? Does the " A chain is only as strong as its weakest link" apply here? I'm thinking of doing this to a car, but if there's no advantage to the splice I will leave that step out and run 18 gauge all the way from the esc to the motor. I see a LOT of guys run the + lead from the ESC to the motor, then splice a piece of wire to that to go to the batt + terminal. This is backwards... they're putting another solder joint in the power path. The way ALL brushed ESC's work is on the negative side, power to the motor should ba a straight path from batt+ to the motor +. Hope that makes sense... |
(Post 5188316)
Never thought I'd say that to a dude... :lol: |
Genius! Thanks for the insight . . .
Perhaps 999 just lasts forvever
and ever... Oh wait... It's all mine, muahaha! Ok, back to some meaningful posts... |
oops... I just went and looked at the picture you referred to, and I see my answer in my previous post doesn't apply to your question...
RcSteve's answer a few posts back is correct... those aren't splices, he stripped the silicone insulation and replaced it with heat shrink to make it thinner. |
Originally Posted by Trips
(Post 5188360)
Ike wins! :lol:
...something :) |
| All times are GMT -7. It is currently 06:13 PM. |
