Info
Originally Posted by R.Dalnogare
im sure this has been asked, but whats a good servo for a 1/12th.
:tire: FUTABA 9602 :tire: |
Any of these will work well. |
Originally Posted by odpurple
Futaba 9602 or 9650, JR 3550 or 3650, KO 949, Airtronics 94145
Any of these will work well. edit- OD, you coming to stockton today? |
Originally Posted by smojoe
I nominate this post to be a sticky for the ever repeated "which servo is good for 12th scale?"
Airtronics has a new digital that I have been using for a while now...the 94761. Its fast, high torque and smaller than any other 1/12th servo.
Well, I'm workin on it, but so far I can't figger out where to stick my balls :confused:
Originally Posted by Mason
the question every tranny is posed with.
What servo saver are you using for it? Does it use standard servo savers or what? Is that about the same size as the KO 3014 servo? Also, I assume since it's so small you've mounted it flat vs angled? I also found these looking around...opinions? http://www2.towerhobbies.com/cgi-bin...?&I=LXNCW3&P=7 http://www2.towerhobbies.com/cgi-bin...?&I=LXGZU9&P=7 Blake |
thanks for the input brian...i'm going to school learning how to make prosthetics and orthotics so i have access to fiber cloth, resin, big pizza ovens and the plates and such....might have some time this year to goof around with it. thanks!
Hello,
Can somebody explain to me the right way to install the IRS kingpin with the nut. I’m nut sure how tight to make it? It's going on a CRC car. Thanks Mark |
I just ordered me a new Darkside Cx2 yesterday for my christmas present to me :) Can't wait till it gets here!
Originally Posted by mrhenning11
Hello,
Can somebody explain to me the right way to install the IRS kingpin with the nut. I’m nut sure how tight to make it? It's going on a CRC car. Thanks Mark I have .20 springs and the nut is on so that you can just barely see the kingpin showing. The nut is on the top side also, and, I have had to compress the nut into the eyelet so that it would seat to the top of the ball. It takes some trial & error until you are able to spin the tire without it rubbing on the kingpin or the nut but they work well!!!! And no more clips!!! |
I'm running .24 springs and you can see two threads after the nut. Does that seem right or too tight?
Thanks Mark |
| All times are GMT -7. It is currently 04:00 AM. |
