Like Tree2991Likes
1/12 forum
Old 09-10-2006 | 02:02 PM
  #20446
TFR's Avatar
TFR
Since everybody is posting their 1/12th. Here is my AH12 that I will be using this winter on carpet. Not yet finish.
Attached Thumbnails 1/12 forum-cimg1359.jpg   1/12 forum-cimg1367.jpg   1/12 forum-cimg1362.jpg
TFR is offline
Old 09-10-2006 | 05:20 PM
  #20447
P2's Avatar
P2
Originally Posted by odpurple
here's the car we'll be running at Vegas:
looks the same but its shorter, narrower and stiffer
OD, Carpet version looks good! I'll need a carpet car too, let me know when they will be available! Here is my OD12 w/disk instead of side tubes.
Good luck in Vegas!
P2
Attached Thumbnails 1/12 forum-od12.jpg
P2 is offline
Old 09-10-2006 | 06:49 PM
  #20448
TimPotter's Avatar
Since everyone else is sharing... My BMI DB12 . Car just gets better every time I run it...
TimPotter is offline
Old 09-10-2006 | 08:30 PM
  #20449
alana07's Avatar
i'm currently running a CRC 3.2r on a asphalt track. so which front upper arm holder is recommended, the angled or flat unit? and why? thanks.
alana07 is offline
Old 09-10-2006 | 08:38 PM
  #20450
Marcos.J's Avatar
Super Moderator
very nice Tim!
Marcos.J is offline
Old 09-10-2006 | 09:23 PM
  #20451
RaceBucks's Avatar
Originally Posted by Justinian
... Has anyone on this forum used a ... lipo in a 12th scale?? ... Does the reduced weight of the lipo make the car's handling unstable and perhaps undrivable? ... I'm guessing, weight differences not withstanding, that my combo would probably have more power and thus be deemed illegal by my fellow racers.... what do you think??? ... Any thoughts??
I've wondered this myself.
Not for racing, but for letting beginners get into 12th, I was considering running a airplane 1800 LiPo 7.4v with a Mabuchi - very cheap. Esentially the same set up as a M03 Mini Cooper but in a low CG, light weight, foam wheel car. Not rediculous high speed, but slower and light weight to save tires, cheap batteries, cheap speed contoller, emphasis on running good lines.
Any thoughts?
RaceBucks is offline
Old 09-10-2006 | 09:41 PM
  #20452
lbckevin's Avatar
Jeff...
What compound foams are you running at Socal (indoor asphalt) for your 12th scale ?
Kevin
lbckevin is offline
Old 09-10-2006 | 10:33 PM
  #20453
odpurple's Avatar
Good luck in Vegas!
P2
P2,
thanks for tearin up the asphalt in TX! watch the website for the V-12
odpurple is offline
Old 09-10-2006 | 10:36 PM
  #20454
odpurple's Avatar
Sweet! love that royal purple anodizing. could you guess that I like purple?
odpurple is offline
Old 09-10-2006 | 10:37 PM
  #20455
odpurple's Avatar
Originally Posted by JayBee
Very-VERY Nice!!! You know what that means don't ya ...
The Museum will need another wing?
odpurple is offline
Old 09-10-2006 | 10:40 PM
  #20456
hi guys got a 12l4 for sale just letting all you 12scalers know
http://www.rctech.net/forum/showthread.php?t=128776
just used once, no scrathes or what so ever on the bottom. with servo s9602, xxl, 3600 battery... crc pink and purple tires. wheele nuts, extra 22 lbs springs, dura shocks by crc, speed 8 body. pdub bumper , just for 160$ shipped
later!!
jinkasama is offline
Old 09-10-2006 | 10:46 PM
  #20457
odpurple's Avatar
Any thoughts?
Funny you guys should mention it, I just drove a lipo 1/12th car today. It was a 12L4 with a 10 turn in it. Sorry I don't know much about lipos so I can't tell you what type and how many cells, but the owner said it was 7.4 volts. The car was so fast it was almost undrivable. Everyone who drove it was grinning ear to ear it was so much fun. I think it needed some throttle or esc adjustments because just touching the throttle would cause the car to leap forward, slow corners required careful modulation to negotiate them. You could hit the straight and with less than half throttle go faster than anything else on the track, then half way down punch it and it would spin the tires until the shut off point. It was so much fun i almost peed my pants
odpurple is offline
Old 09-11-2006 | 05:22 AM
  #20458
that car was f'ing FAST!!!! half way down the back straight when you guys would nail it, you could hear the thing like bunch up and spin the tires. poor little car was screaming for mercy
norcal tom is offline
Old 09-11-2006 | 05:46 AM
  #20459
Scottrik's Avatar
7.4v would be a two cell lipo--they run 3.7v each.
My thinking for lipos was that a single cell would probably be close lap time wise to a "normal" 4-cell car, off-setting the reduced voltage with the substantially reduced weight allowing higher corner speeds and quicker acceleration/deceleration. Another field-leveler might be running the two cell lipo with a 55-65 turn lathe motor. Not surprising they're a rocket with a "normal" motor as you're pumping even more voltage into it than we had in the heyday of 6-cell 1/12 way back when...with a way better motor today.
That said, I'm opposed to lipo's in cars. There's WAY too much to go wrong (like burning down your house around them) for the "average" car racer to keep track of.
Scottrik
Scottrik is offline
Old 09-11-2006 | 06:10 AM
  #20460
yyhayyim's Avatar
Default Today's Lipo's
No need to worry about LiPo's these days. That was a concern maybe 10yrs ago, but today's LiPOs are high-tech purposely made with rc in mind. They are as safe as regular 6 cell, and will never get as hot as 6 cells, dont need to be discaharged, ever, and can be charged time after time. They have much lower resistance and will not catch on fire unless you BBQ them. Everyone is doing LIPO's, and according to ROAR staff, they will be mainstream within 2 yrs and make 6 cell racing a thing of the past. They are only working on reconfiguring the voltage from 7.4v to 7.2v or less.
yyhayyim is offline
