Like Tree2991Likes
1/12 forum
Old 08-30-2006 | 03:40 PM
  #20281
Vic_rds,
Yeah you got a good deal.
I don't know of anyone who races a sixpack, but it looks like you could buy a T-Fource chasis and convert everything over. Or just run it as is.
Great buy.
Greg
Greg45231 is offline
Old 08-30-2006 | 05:23 PM
  #20282
Diggity's Avatar
Default New Diggity Designs D12 V2 kit Now Available
Just wanted to let everyone know that the D12 V2 kit is now available to purchase. If you would like to purchase one then go here: D12 V2
Here are some pics of the black production kit:
If you would like to see more pics then go here: Pics
Diggity is offline
Old 08-30-2006 | 06:43 PM
  #20283
hey the digler here again. Been out of electric for a long while. Whats the deal with the big capacitors on the ESC's? Is this a must or just insurance? I am planning on a Novak GTX running stock and maybe 19 turn.
Thanks again for the help.
THE DIGLER
thedigler is offline
Old 08-30-2006 | 07:18 PM
  #20284
RichChang's Avatar
Hi Bill,
Like Ray said, you can use a straight edge.
Another way is if you have the droop setting blocks for TC (the 2 rectangle blocks that you lay the chassis on and the gauge to measure droop at the arms) you can use that also in the same way and just measure at the back of the motor pod.
-Rich
Originally Posted by B-B
What is the best way to measure your pod droop?
RichChang is offline
Old 08-30-2006 | 10:24 PM
  #20285
dr_hfuhuhurr's Avatar
Can someone explain what pod droop is then please?
I can see how pod droop would work on a link car but not really on a t-bar car.
dr_hfuhuhurr is offline
Old 08-30-2006 | 10:27 PM
  #20286
Rob Phillips's Avatar
Any one running GQ's? I wanted to know what compounds have been working for 19t carpet. Thanks
Rob Phillips is offline
Old 08-30-2006 | 10:35 PM
  #20287
burbs's Avatar
Droop is the angle of the pod in relation to the chassis, when the pos is fully extnded back.. droop is a very usfull tool in tuning, especially on a t bar car.. Put the chassis on a flat surface with the pod hanging off.. have the center shock disconented.. you will see how the pod drops down..
below is an explanation about pod dropp Eric Anderson or EA put on another site..
Ive found a coulpe different things that will require more pod droop. Rough tracks. A longer center shock (IE More pod droop) is needed to keep the tires in the bumps and smooth the car out. Also more pod droop will give you more steering center of the corner.
The more angle the shock is on the shock mount the less weight transfer to the front tires therefor less steering and it also makes the shock spring a little more progressive feeling. The higher the shock is mounted the more weight transfer to the front giving more steering and a more linear feeling on the spring.
burbs is offline
Old 08-30-2006 | 10:46 PM
  #20288
burbs's Avatar
here is an link to the rc4 less thread.. These are Gq tires, just re badged..
http://www.hobbytalk.com/bbs1/showthread.php?t=90438
burbs is offline
Old 08-31-2006 | 01:26 AM
  #20289
JayBee's Avatar
Hey burbs, is your avatar meant to say kiss your azz or are you saying come and get it?
JayBee is offline
Old 08-31-2006 | 01:27 AM
  #20290
Pro ten Holland's Avatar
Moderator
Originally Posted by hugovdb
I just ordered a 3.2R to! Some good tips here, thanks. Also, what tires does the kit come with (I dont have it jet) ? Does the kit include crc tube lube?
Thanks,
-Hugo
The kit tires of the red version are Grey rears, Purple fronts.
Good starting point, although I prefer pinks in the rear.
Pro ten Holland is offline
Old 08-31-2006 | 06:03 AM
  #20291
LMFAO!!!
Burbs...(and EA indirectly) thanks for the explanation. That's what I've thought it was but the discussion here confused me.
Old 08-31-2006 | 06:28 AM
  #20292
Turbonium's Avatar
hey Rob... i have some of those i have run before... when i get home, ill check the compounds again.
one thing i do like about them is that they make front dual compounds, like the TC's...
Turbonium is offline
Old 08-31-2006 | 07:07 AM
  #20293
GQ's seem to be very good tires, excellent wear on nitro. I am going to pick up a couple sets, just not sure what compounds to get.
Old 08-31-2006 | 07:17 AM
  #20294
How do you guys line up your servos?
I have a Rev4 and I will using a 94145 mounted flat to the chassis. Obviously it has to be centered, but what about tie rod angles, both front to rear and up and down. I have seen a few different ways of doing it, some of them even mount the ball studs on the opposite side (pointing toward the servo). Also, which holes in the servo saver (Kimbro) would I use with this servo mounted flat. Thanks
Old 08-31-2006 | 07:25 AM
  #20295
Turbonium's Avatar
http://www.teamspeedmerchant.com/MikeDumasCle03.html
pic of Dumas' cleveland car... i have mine mounted like that. need to remove the blue from the AE mounts, tho... everything else is silver.
