hey guys,i just want to let you know that our latest version of the 1/12th conversion kit is going to be available for shipment this week.i made the final changes and i am starting a production run on monday. :)
GRP 1/12 tires
any of you guys here ever tried GRP 1/12 tires on asphault before? if so, how's the wear rate and performance? thanks...
Originally Posted by TFR
What guage wires do you use to fit that black and red motor wire underneath the batteries?
It is 16ga from Castle Creations. BTW there are 3 different cars pictured and we run the same wiring layout on all of our twelves. take care, shaggy |
Scottrik, my dad is "burgboyz", and no we stick with the 20's.
Occasionally he'll slap on a set of 22's just to try them. (very rarely though) |
Originally Posted by shaggster
My dad & I got this trick from JB.
Occasionally he'll slap on a set of 22's just to try them. (very rarely though) Scottrik |
Luv the color coded idea. But, we haven't tried them yet.
I know guys that have and they like 'em!! |
I got the same wires and even some better ones that are smaller in diameter but it just doesn't sit well with the 3800 batteries I'm using... :cry:
If you are using Castle Creations 16ga they should fit under the batteries with room to spare. I think you could even fit three wires if you stacked the third wire (can you say "brushless"?). I have had no problem with this set up with 3300, 3700, and 3800 mah batteries. Another trick is to strip the insulation from the wire where it goes under the batteries and shrink wrap it. This gives you a very small diameter wire and allows the use of other brands of wire (my favorite is Dean's 16ga) |
For the steering link on my SP12M can I get rid of the rods and go with turnbuckles? What would my advantages or disadvantages be? Thanks.
Originally Posted by BSchorr
Good to hear Jason, My plans are a DB12 and a BMI T2! What is the expected price?
Hey Jason,
How did the diff rings go in the end? Will they be included in your latest conversion. Darren |
the diff rings worked extremely well.the car felt really good.there actually was a difference in handling believe it or not.the difference in the smoother more free diff made the car rotate extremely well(better than usual).im not going to include them in my chassis conversion but they will be in the full car kit.the conversion kit almost is the full car in a sense.i just need to put a few more things in there :cool:
Originally Posted by Marcos.J
I ran them before and they are pretty equal to the Parma foams
| All times are GMT -7. It is currently 01:02 AM. |
