it the kimbrough servo saver for airtronics the same as for jr?
Houdini, do you have any pics of the car? Is it in good shape? Does it come with any spare parts?
The 3.1 Houdini is refering to is brand new kit.
23T for JR, KO, and Airtronics. 24T for Hitec and 25T for Futaba.
Mark |
thanks!
Has anyone tried the CRC C60 Evo3 LMP body? Looks like it has alot of overall downforce.
-Korey |
does anyone know the spring rates for team crc side springs and center springs in-order from soft to hard? why wont they include this in the package? :rolleyes:
Same as Speedmerchant, and orange is NLA. This is to the best of my recollection, it doesn't seem to be published anywhere anymore. |
Originally Posted by odpurple
From softest to hardest: orange, blue, white, red, green, purple.
Same as Speedmerchant, and orange is NLA. This is to the best of my recollection, it doesn't seem to be published anywhere anymore. thank you! what about the center springs? |
Here's what I have in my notebook on springs. It's kinda been collected over time from a few different places. Hopefully, this can help others out, too...
Center spring: Preload on the center spring is used only for setting ride height. if you want the car stiffer or softer, you need to change the spring. A stiffer center spring usually makes the car steer more in the middle and exit of the corner (accelerating). The only place this really doesn't hold true is if the track is very bumpy. Because the car is too stiff, it is chattering in the bumps and losing traction. More mid/exit steering: stiffer spring Less mid/exit steering: lighter spring Olive Green: 6 lbs Silver VCS: 8 lbs Blue: 10 lbs Gold: 12 lbs Red: 14 lbs Copper: 16 lbs CRC Stiff Silver CRC Super Stiff Silver Side spings: Side springs control how reactive the car is around center. Stiffer springs equal more initial turn in, less chassis roll and more steering response (although most noticeable around apex). More entrance steering: stiffer side spring Less entrance steering: lighter side spring Blue: soft White: medium Red: firm Green: x-firm Purple: xx-firm -doug |
Ooooh, I'm slow. GOOD memory OD!
Black 4lb, Olive 6lb, Silver 8lb, Blue 10lb, Gold 12lb, Red 14lb, Copper 16lb Speedmerchant Black 17lb |
What about the springs on top of the discs that slide around on the rear pod top plate? Are those adjustable? What do I adjust for side2side movement?
| All times are GMT -7. It is currently 05:01 AM. |
