Brushless Project Mugen Mrx 3/4
The Car Mugen Mrx 3
Motor mount speed passion serpent 960
[COLOR="Blue"]Car Disassemble For Chassis[/A]
Chassis Stock Mount Hole Weld In
Now Drilled New Holes For The New Sepernt Mount
PRETTY
In Place
Car 80% With 6s Lipo Batt
Car With Lipo In
For Brakes Small Tack Weld Needed
Done!!!!!!!!!!!
Fill Free to email me [email protected]
PRETTY
In Place
Car With Lipo In
Done!!!!!!!!!!!
is that a mmm and a 2200kv setup?! crazy stuff! i want to see a video!! i am thinking of doing this setup also!! keep it up...peace
wohh!! Iīm beginning doing the same but with an edam razor pro... Videos please!!
Hi, I have a Mugen MRX4 just sitting around after I bought my Motonica P81.
I was planning on making something close to what you have come up with, biggest question is the battery. What lipo battery are you using?
I was think of using this one: http://www.hobbyking.com/hobbyking/s...5C_Lipoly_Pack
Also I was thinking of placing my MMM just in front of the motor, on the upper deck. Any weight balance issues? Does this explain the location you have used?
Any help and feedback would be appreciated.
Thanks.
Thanks.
Which ratio are you using and what temp has motor and esc after running? There is another motor mount options? i donīt like the idea of drilling the chasis. Why did you place the esc there?
Regards
Regards
......Wow, that's a clean installation......
......I bet you'll miss the smell & sounds of nitro......anyways, good luck with that set-up. Are pinion/spur mesh an issue for you ? Please give an update on, for example, the strength of the tack-weld when you get enough run-time-Greg
Thanks.
Thanks.
Something new about this mrx vaboy?
