Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 07-23-2009, 07:57 PM
  #27436
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by Owen RaCing
Just got ahold of a Mi3.5 and I have to say im floored at the thing. Its pretty nice car. I never gave shumacher enough credit, its a nice ride
Haha to bad its your dads. One up him and get a MI4 punk
There dialed!!!
BlackedOutREVO is offline
Old 07-23-2009, 07:59 PM
  #27437
CMB21's Avatar
Hey guys,
It's been a while since i had to take a break from rc. I am trying to figure out what gear ratio i need to run in my Mi3 for the 540 stock class (ie running the 540 Johnson silver can motor) Will also be running lipo batteries.
Currently i have 31/70 in the car, is this ok or should i be using a different ratio? What FDR?
Thanks.
CMB21 is offline
Old 07-23-2009, 08:04 PM
  #27438
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
There dialed!!!
I know huh? I need one. Im a car collecting addict. Is there a addicts class for that yet?
Owen RaCing is offline
Old 07-23-2009, 08:05 PM
  #27439
CMB21's Avatar
Nevermind finally found my old post, seems 31/70 is what i should be running.
CMB21 is offline
Old 07-23-2009, 08:07 PM
  #27440
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by CMB21
Hey guys,
Thanks.
we normally run our silvercans between a 5.8 and 5.0 depending on track layout. I would look at a bigger spur the johnsons like it.
skypilot is offline
Old 07-23-2009, 09:03 PM
  #27441
CMB21's Avatar
Oh ok, well i was told before that an FDR of 4 - 4.05 was the way to go for the silver can.
CMB21 is offline
Old 07-24-2009, 09:22 AM
  #27442
1shnot's Avatar
So trying to search for front spool cvd chatter,tried exp and DR on my radio, and still chatters alot.. only thing I havent done is ca 2mm shim to my knuckle
anyone have any other ideas?
1shnot is offline
Old 07-24-2009, 10:16 AM
  #27443
Skiddins's Avatar
The only other thing I've seen done is modifying the steering hubs and spool outputs, then using Xray's ECS driveshafts.
I have been told by the guys that have done it that it works extremely well.
Skiddins
Skiddins is offline
Old 07-24-2009, 10:30 AM
  #27444
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Originally Posted by Skiddins
The only other thing I've seen done is modifying the steering hubs and spool outputes, then using Xray's ECS driveshafts.
Skiddins
what spool outputs are they using?
Marcos.J is offline
Old 07-24-2009, 10:37 AM
  #27445
Skiddins's Avatar
I believe standard, but they had to be filed out to accomodate the thicker Xray style blades.
Skiddins is offline
Old 07-25-2009, 01:16 AM
  #27446
LOSI123's Avatar
Trader Rating: 63 (100%+)
What are the blue orings that come in the shock seal pack for the mi3 used for?
One pack comes with 2 clear orings & 4 blue orings
LOSI123 is offline
Old 07-25-2009, 02:09 AM
  #27447
vazzo's Avatar
Trader Rating: 101 (100%+)
Ill show ya next time I see ya dude, I still havent been able to get it off.
On another note I'm thinking of picking up a brand new SpeedPassion GT v1.1 cheap and just wanted to know if there is any upgrade software available for it? Also is it good enough to power a 5.5 brushless motor?
Cheers
Adrian
vazzo is offline
Old 07-25-2009, 05:33 AM
  #27448
R/C Tech Elite Member
abailey21's Avatar
Trader Rating: 37 (100%+)
The 4 blue o-rings are for the Cat SX, the clear o-rings are for the TC shocks
abailey21 is offline
Old 07-25-2009, 06:26 AM
  #27449
1shnot's Avatar
Skiddins
That sounds like an awesome idea, what is mi3's length of driveshaft? and what other mod do we need to make it work? just file away the spool slot to fit xray's blade?
1shnot is offline
Old 07-26-2009, 07:17 AM
  #27450
LOSI123's Avatar
Thanks adam
Also whats the strongest drive shaft blades to run in the front of an mi3 with a spool, mine apear to be cracked. (do the newer ones fit?)
and is thier a way to tell the rear toe with out a setup station, like mm of spacers = degrees of toe?
LOSI123 is offline
