Schumacher Corner
Regional Moderator
Like Randy said, its all in your set up. And also in your driving style. I usually run sway bars front and rear on all my cars, especially on carpet. But, I was just running on medium grip carpet and didn't use any sway bars at all (as per the standard carpet setup) and it worked really well.
Regional Moderator
I agree, the grey shirt better.
I've personally never run swaybars on foam carpet. Unless I put a swaybar on the front to take away alittle traction.
sorry it's for rubber tyres...
I feel like more upwards rear shocks gives more stable,more grippier rear end but people always says more inwards much softer=more grip I don't know what's wrong with me???
I will try Kev's vegas setup tis week let's wait and see whays gonna happen tomorrow ...
Standing the shocks up with add steering and make the car react faster.
Leaning the shocks in will soften the cars reaction and add grip.
Thats on the towers though. Bringing the shocks in on the arm will soften the suspension. You can get alittle more steering all-around by moving the front shock bottoms in one hole.
Stay away from trying to explain it in terms of more or less grip as it could be confusing.
My 2 cents.
I'm buying a MI3 to run stock rubber and 19t rubber with to replace my used MI2EC. None of the tracks here carry parts but I don't feel like being a sheep and running what everyone else has. So what spare parts or aftermarket stuff should I get from the get go before assembling my new kit? I want to only have to build this once the right way. I plan on running a brushless setup probably novak. So any help on what to buy before I build and what to stock for races would be great help thanks.
Just a quick question.
All the time ive been racing ive never ran any roll bars.
Over the last year or so more and more people seem to be running them. Obviously they stop the car rolling as much and i imagine that takes some grip away.
So my question is why would you want to put them on ? How would it change the car ? Do you think its worth a try ?
Some people seem to run them outside on tarmac when i always seem to be trying to get more grip but by fitting them they are taking it away so im a little confused ?
Make sure to use threadlock, most people say you dont have to, but my experience tells me that you do. Especially on the long screw that holds the spur gear assembly in place. The spur gear will be chewed up if that happends (happened to me this weekend).
I recomend a top deck...the stiff one maybe...any shunt in the rear can break the origional top deck
You can't just brake a top deck. In all my years of racing, I've only seen one broken top deck and that was with a car landing on it's side on the straight and then get nailed in the roof at 60mph.
Btw, if you run rubber tires, try the flex deck, I haven't tried it, but a friend of mine has and it dialed the car out. Mine is dialed with the standard deck, but I'll try the flex one very soon.
some people says flex top deck Causes the tweak..
There we go
But if You need extra extra grip worth to try...
Top deck...
My top deck broke two weekends ago without being hit by another car. It was the flex one that comes with the kit. I caught the inside of a turn and broke the C-hub, arm, bent the CVD, and broke the top deck in half. So now you know about two.
