Ask Paul Lemieux, RC America/MOTIV/Gravity RC
#2236
Hi Kevin, I run the LRP Flow with a 4.0 boosted pretty high, 30deg timing geared 25/98 for most tracks. thanks!
Thanks!! was fun, hopefully next time i will be in a little better health and enthusiastic.
That is what its all about! Thanks
Hi Edward, i would suggest soft rear and hard front for asphalt. the only problem that you may run in to is that the tires are pre trued to 45mmR and 43.5mm front. for low grip that is not likely to be big enough, med and high grip it would likely work well. if they are not big enough, special asphalt tires will have to be special ordered which will then be tailored to lower grip asphalt tracks.
Hi Peter, for 13.5 i can only suggest starting at a 5.5 ratio, 30deg motor timing and boost it from their and keep track of temps. if you are going to do a lot of testing i would also try a green rotor. As for mod i would go with a 5.5 because boosted it can be as fast as anyone but non boosted i can be pretty tame also. Good luck!
I think that the norm now is to have 0 rebound, i think that when you see 25% on a set up sheet, that is a lot of time because someone is attempting to have the least possible amount of rebound but still the shaft will push out just a little. in general i think that 0 rebound just drives smoother and the car is more predictable to drive.
No problem, glad i could help so you could get to having fun!
Ha Ha, I didnt get to watch you after that but im glad your week got turned around. was fun.
See ya!
I Am yet to try the 2stage but i think it could be a good option. the stock inserts have the most grip of all right away but then it does get too soft quickly, the molded inserts start with less grip but then soften up and have good traction. it is possible that for here the 2stage could be the best compromise. If i try it i will let you know.
Paul it was great having you as our guest at Jeff's RC Studio! We had tons of people show up to meet Paul and get some tips and an autograph! We highly recommend inviting Paul to your hobby shop to do the same, it was a huge success!
We hope to be able to book you again Paul in the very near future. Everyone wants you back.
Your friends at Jeff's RC Studio!
Looking at purchasing some of your 1/12 scale tires here in Japan, and wondering whats a good tire combination for outdoor asphalt? The traction level is low-medium, sugar water is the main traction agent. The temperatures are in the high 30-40 degrees Celsius. Also, I'll be using paragon black can for traction compound.
Cheers.
Edward
Cheers.
Edward
Hi Paul:
Is there a rule of thumb regarding shock rebound? I see some setup sheets where some is used and many where it is zero. My guess is it has to do with the track smoothness but not sure. I was taught to set about 25% rebound for my TRF416X for an asphalt track with some bumps in it. I'm guessing that rebound tempers the spring action.
Paul, thanks for saving my weekend at the Reedy Race! I wasn't having the best of luck in the first 2 qualifiers. In the 3rd qualifier, my motor had shifted on the warm up lap. Paul came to the rescue with tools to set the gear mesh!! From that point, my luck changed for the better. I think it was a sign for me to go back to running an Xray Thanks again!!!
See ya!
#2237
Hey Paul,
I would like to say thanks for keeping up with a thread like this, it really helps out newer guys in the hobby, like myself, and im sure the experienced guys learn a lot from you as well. I had the great pleasure of racing with you at the 2012 on-road fuel nationals in the Finals for sedan. I am came to this thread to ask you what on the stock setup for a T4 (17.5) would you change, or is the car great right out of the box. I have not raced electric very much but i know i like the feel of the NT1 with some adjustments to springs, shock oils and diff oils. I read that some people are putting heavier shock oils and diff oils in but i wasn't sure where a good start was. I will mainly be running at Kissimmee when the new asphalt is laid down next month.
#2238
Hey Paul,
#2239
Thank You Paul!
I was hoping you would have a LRP, What settings do you run?
I'm running a 5.5 with 1.4 firmware, can you recommend a base setup?
Thanks again
Kevin
Thanks again
Kevin
#2241
Hi Paul, would you be posting your Reedy setup for the T4? Didn't get a chance to talk to you with all the hustle and bustle at the race.
#2242
My son and I got to meet Paul last night at Trackside Hobbies.
Wow--what a class act of a guy!! I'm sure a guy like this is being pulled in a million different directions and yet he's VERY approachable and willing to take whatever time to talk and visit.
Paul is a real credit to our hobby and we are very fortunate to have him!!
#2243
#2244
Hey Paul,
http://forum.teamxray.com/xform/inde...D=367&setup=t4
Im not really a believer in needing a different set up for mod and stock. so i would go with it. was your diff and shock oil question in regard to the T4 or the Nt1?
for starting speedo settings on a flow i would go with. 5,2,0,3,4,2,0. fan on speedo and motor. hopefully that gets you in the ball park.
Flow settings 5,2,0,2,3,1,0. again fan on motor and speedo. Good luck!
You should have come by!
see ya
blush, lol
#2245
Toledo Ohio
hey Paul,
curious, have you ever ran your t3 12 at the outdoor Toledo asphalt track? just wondering what your setup was for that car, or what it would have been, at that track.
i'd appreciate any insight.
my car seems to handle ok, just looking for that little something more
right now im runinng:
4.5 motor timed and boosted
middle roll centers for the arms
#1 hole upper for front
#2 hole upper for rear
rear shocks laid down, using the '11 shock tower
somewhere in the middle for the front tower
350cst in the shocks
ofna diff loc in the front
700cst in the rear
thinner top deck, took out the 2 screws for more flex, stock lower
wider hubs for the front
narrow hubs in the rear
sorex 32s all the way around
thanks for your time...
700cst in the rear
#2246
Hi, No prob!. For the T4 this is my go to set up when the bite is med or high, the only thing that you might want to test would be 4deg caster instead of 6.
#2247
The solder tabs on my TP motors are coming loose, the A tab on 2 stators. You would probably get new ones, what can I use to get them solid?
#2248
Can you help with a low bite setup? I run at Jackson the site for 2011 Nats, it's early in our outdoor season and very low bite. It comes by the 3rd round but has been raining between race days and washes that away
#2249
hey Paul,
700cst in the rear
700cst in the rear
