Old 08-03-2004, 06:41 PM   #496
Check the motor dude....Try putting in a different motor
The Black Kat is offline   Reply With Quote
Old 08-03-2004, 10:20 PM   #497
Wency_TA03R-PRO's Avatar
Exclamation
Bro I already did after I wrote the message board... anything else to do just to solve the problem?..
Wency_TA03R-PRO is offline   Reply With Quote
Old 08-03-2004, 10:24 PM   #498
New speed control?
071crazy is offline   Reply With Quote
Old 08-03-2004, 10:26 PM   #499
Number 11's Avatar
Wency is the GT7 brand new? If it is did you program it? Did the car work before and just stop?
Number 11 is offline   Reply With Quote
Old 08-03-2004, 11:23 PM   #500
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
Default ?graphite r More R less
hey guyz not really new to r/c but. will it make a big difference if i dont upgrade my tc3 to the graphite? as far as handeling/weight issues?if so r not plz xplain y would it benefit me r y it wouldnt be a big of a deal to upgrade.im currently usin the mike blackstocks 2004 snowbirds setup off the associated website an the car is practically dialed to my standards.i run expert stock sedan. the car is really free an clean.
Steven
crACkeD ChaSsiS is offline   Reply With Quote
Old 08-04-2004, 01:30 AM   #501
Exclamation
Yup!! its 3 months old.. I did reprogram it.. after 3 months it runs smoothly on the tracks.. no problems encountered like this one..
what else can I check and do??..
Old 08-10-2004, 10:50 PM   #502
Mike - Did you goto the Tamiya America race last weekend ? How did you do ?
Chris Reilly is offline   Reply With Quote
Old 08-10-2004, 11:07 PM   #503
Default axle spacer
hey mike which # axle adjuster are you using.. i run on a track that is sprayed with vht.. thanks
teamatlas is offline   Reply With Quote
Old 08-11-2004, 12:17 AM   #504
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
hi mike: i dont know if you've posted somthing on this before but hope you can help me out. i was just wondering what a good starting set would be for the rc12L3 on an outdoor asphalt, medium bite track. white tire combos, suspensions settings, body would be a good starting point? thanks!
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 08-11-2004, 12:26 PM   #505
JoshR 85's Avatar
HeY!!!
Hey Mike i got a question about the reedy quad mag.... some reason this motor just aint as fast as the chameolon it aint turing the rpms and i have to gear the heck outa it and i blow threw brushes and have to cut it every run because of how i'm gearing it and i played w/ the springs and brushes and i don't know, so i'm wondering what did you do to your at the novak race back in january to make it so fast if you can remember??? thanx
JoshR 85 is offline   Reply With Quote
Old 08-11-2004, 07:40 PM   #506
Trader Rating: 14 (100%+)
Chris Reilly There is a foam tyre asphalt setup on the AE website, it is worth a try. The link is http://www.rc10.com/racerhub/setup/r...alian_2002.pdf
Hope that helps.
Miami is offline   Reply With Quote
Old 08-12-2004, 05:31 AM   #507
ROBORAT's Avatar
Thanks miami but i was referring to a set up for the 12th scale, not the tc3.
Old 08-12-2004, 08:33 PM   #508
E-volo.. Looser front diff will make it turn better getting into the corner but not so good center and out... I usually run my front diff tighter then my rear if that helps.... As for the 1/12th scale sometimes when i can not get the car to rotate through the center i will put a .020 shim under the front ball of the t-bar...
Wency_TA03R-PRO .. I wish i could help you more.. But what everyone said on here is what i would try.. But i think there might be a problem somewhere in the speedo...
crACkeD ChaSsiS.. If you are going to race .. I would get a graphite chassis for sure.. It will be less flexy and lighter....
Chris Reilly.. Nope... I was on vacation .... Now time to get ready for the worlds and the Gas nat's,.... :-)
teamatlas... With IRS pod plates i run #2 up with a 1.88 tire....
ROBORAT .. Here is my setup from the nat's in portland...
Front End... .018 front springs with TRinity red stuff for dampening.. 3 deg caster -1 deg camber alittle toe out 10 degree block... T-bar .063 t-bar with all three screws in the t-bar 40 wt oil in the shock with the green spring... Double pink fronts and pink rears.. Tire size 1.74 fronts and 1.88 rears.. Protoform speed 12 body... If i left anything out let me know ...
JoshR 85.. I run 767's with + cut on the positve and - cut on the Negative with purple springs or stiffer... he negative cut you do side ways....
Hope I could help..
Mike
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 08-12-2004, 09:07 PM   #509
JoshR 85's Avatar
Hey!!!
Thanx Mike, did you have to gear it at real high roll out or no???
and also would you happen to know if alum. diffs will slow your lap times down from the plastic diffs??? and last question will the double pink orange, and double pinks wear faster then the orange purple, purple because they're softer or no, just wondering cause everyones saying go to them and i might pck up a tenth because they stick better because they're softer??? good luck at the world and gas nats.
Old 08-12-2004, 09:40 PM   #510
Default ty
ty Mike really appreciated.
Steven
Mike Blackstock & Team Assoicated back together again Kropy Electric On-Road 22 07-16-2008 07:18 PM
Where does Mike Blackstock GO next???? RCPIRATE Electric On-Road 104 07-15-2008 07:08 PM
CEFX signs Mike Blackstock Josh Cyrul Electric On-Road 39 05-17-2007 04:35 PM
Team br00d signs Mike Blackstock..... EddieO Electric On-Road 29 05-15-2007 09:24 AM
Congrats to Mike Blackstock on his move back to BIG T Tres Electric On-Road 0 10-26-2005 11:16 AM
