LOSI XXX-S, Tips and Tricks, Open Mod, etc
#706
No problem. I will just make to order, will be a good price too.
#708
What if me or someone else mailed you a stock losi spur, so you could get the exact dimensions of the actual teeth? From there I'm pretty sure you just need the depth, diameter, ect of the actual adapter, and the spacing measurement for the screw holes. Sorry if I'm not describing the technical stuff correctly... but anyhow I have a stock spur I could mail out this week if it would help. Let me know.
#709
Spur gear adapters !
Perhaps some one could make plaster molds ad send them to fathead ? Or he could just dremmel off most of a spur gear leaving only the belt drive part of the gear. Mounting holes could be drilled by buyers/end users for their specific spur gear application ????
OOPS
OOPS
#710
fathead- if you can get these made, I'm sure we could work something out so that a batch could be mailed here, and then sold individually from there. But that's all just thinking ahead... something to look at later on. I'm pretty sure a good number of these will get bought up though. I'd take at least 3 or more myself.
#711
I really only need dimensions of everything apart from the teeth, the teeth are a standard profile to match the belts, software I have automatically produces the correct profile all it needs to know is the number of teeth and profile code which I have, I could also do different number of teeth easily if needed
#712
If people are interested they can look at my Facebook page, Slavich design, to see some of the stuff I have done, currently just doing stuff in my spare time
#713
Also do people want M3 tapped holes or imperial equivalent for spur mounting? I only have M3 tap currently.
These will all be the same price regardless of if I make 5 or 50,not looking to make big coin, just want to help fellow racers out
#714
Once I've got a few dimensions and had a play with drawing/machining one I will let all you guys who have offered to send me spurs if I get stuck, thanks for all the offers!
#715
Adding or subtracting belt teeth
By adding or subtracting belt teeth, you could use the yellow or green XXX4 belts with the standard tensioner and pulley ( more teeth ) and by subracting a tooth or two, Josh Howards' belts could be used without modifying the chassis !!!!
#717
I think I will do at least 2 pairs of spur mounting holes, 1 tapped M3 and the other either just drilled or tapped 4/40.
I can easily do 2 or 3 different tooth counts, just let me know guys.
Different tooth count is as easy as changing the number in a box, here is 23 & 21T, also generates spokes automatically in various configurations
#719
Thank You
fathead, I've checked out your facebook page and you sir, are the consummate professional , a true artisan as well as quite an eye for detail as well as completely grasping many or all aspects of RC cars. I feel honored that you are taking this on. THANK YOU !!
#720
You give me too much credit good sir!
I'm just a guy who likes to make some stuff in his spare time!
I get the most reward out of doing the little jobs (like this) that pretty much wouldn't get done otherwise.
