LOSI XXX-S, Tips and Tricks, Open Mod, etc
#1021
only place I have found belts is E-bay. just look up losi xxx-s
#1024
Would the same basic setup as a current model Tc work on this car for a small tight carpet track ?
#1025
you don't have any carpet setups?
#1026
Found some pavement setups but not carpet.
#1027
Ingolstadt is one to go, here you have some setups:
http://kajman.witam.net/rc/xxxs/setup/
Might have some on paper too if this one is not ok for you.
Still have one xxx-s g+ prepared strictly for carpet with all hoop ups
#1028
Wow thanks Kajman, I will give those a try.
#1029
Just my luck the carpet track closed now running od loose grip polished cement.
#1031
loos grip is what xxxs likes. Mount overdrive pulley in front, high gravity center and go on If you don't know what tires, I know some chinese rally tires which work great on slippery surfaces
#1032
Thanks Kajman I have perilleli rally tires from Hpi. They work great. Will look for the overdrive front pully.
#1033
Same tires, but from china are available on ebay, they cost 7$ and are much much softer than HPI
http://www.ebay.com/itm/321152071185...%3AMEBIDX%3AIT
Or cheaper blue
http://www.ebay.com/itm/121506122715...%3AMEBIDX%3AIT
Or cheaper blue
#1034
Thanks Kajman I will get some and give them a try.
#1035
this car carries more corner speed than my Detc 410. Is it the ball dif's?
