LOSI XXX-S, Tips and Tricks, Open Mod, etc
#812
Carbon Fiber Bottom Strap
Hey fathead, what you think about these?
#813
Piece of cake if I can have a sample to work from, either stock one or carbon one.
#814
#815
#816
Even easier, just need the post diameter and distance between
#817
With the aftermarket belts available to us now, xxx-4 belts are of little relevance IMO... All I care about is having an adapter that lets me run Josh's belt Even if I had a XXX4 belt, eventually it will be useless after enough use. Keep it simple I say.
Will be picking up a Fathead adapter as soon as it is available!
#820
#821
Anyone have pics of MF mounts next to standard ones?
#823
Yes I have some stickers and will put some in with every adapter or part
#824
http://www.rctech.net/forum/attachme...g-dscf0016.jpg
The rear blocks are shown at the bottom of the pic. Basically they were two-piece and you could alter the height of the blocks (depending if you ran them as one piece or two piece / stacked). I have some I could send if needed....
