Sway/stabilizer bars fitted to front & rear (??) >
Old 10-09-2009, 06:52 PM
Default Sway/stabilizer bars fitted to front & rear (??)
Hi there. Ive a couple of questions about anti roll/stabilizer bars
Some cars seem to have Sway/stabilizer bars on the front and rear.
Should they be fitted to one end of the car only- as they 'move' some of the grip to the opposite end of the car?
Do they only work effectively if the springs/suspension are quite soft ??
1101 is offline
Old 10-09-2009, 09:06 PM
chrislow's Avatar
Trader Rating: 17 (100%+)
I thought they moved transfer load left to right, not front to back, so can use either front or back or both, depending where you want more grip...
chrislow is offline
Old 10-09-2009, 11:19 PM
Oops, you're correct.
I was totally off track with that one, just had a look in the Hudy setup guide.
1101 is offline
