XRAY T3
#796
Just sharing
got t3 since it came to my shore, after 18 days of driving i had a hard crash and it chassis at front is ripped and also servo saver is chip. Since we got no parts till late december i have no choice but to run my spare t3 till we can have parts. Cant complain much as after 18 days and almost 2000 laps any car will go i guess.
Cheers
Cheers
#797
From their testing they could not conclude there was a flaw in the design. So to appease the people who are having issues they developed the part.
There are a lot of us who are thinking the chassis will only break when, 1. Screw is backed out, 2. Chassis is not CA'd. I would test this theory myself with a hammer but I'm not rich. Till then, I'm going to make sure the screw is tight and run the T3 as is. If I need a stiffer front or I'm running mod on a hard board track, then I'll put in the optional piece.
#799
Trader Rating: 20 (100%+)
Did you guys catch how much torque he applied to the screw??
Need to buy new 2mm wrench!!! i guess that may also be the trick! DONT BE A "WUSS" CRANKDOWN ON IT!!! then test it with a hammer!!(J/K)
#801
he should hummer that from out to centre for proper test
two holes next to each other so close to chasis diff cut...
#802
I built mine and ensured I prepped the holes with CA and then used medium loctite and some good old torque on the wrench when seating the screws (before I even saw this video).
...it seems VERY solid to me and if the screw doesn't back out it should be fine since you are keeping all of the surface area of the mount against the chassis. If there was play in there or the screw vibrated out I can see the potential for the breaks that have been shown.
#806
Suspended
#808
I have a question on the camber change.
I built my T3EU as the manual suggested.
- Camber link: #3 holes on both the front and rear shocks tower
- Shim: Rear 4mm shim above the upright / Front 1mm above c-hub.
- Camber: rear 2deg / front 1.5deg
When setting camber (Hudy setup system), I push down in the center of the shock towers, I notice no camber change at the rear and only +0.5deg in the front. If I push down on one side, say rear right side of the shock tower, the rear right would become 1deg camber and the left become 3deg.
I think this is wrong? Since I thought the side being push down should have more camber for more traction? I also have a t2 009, also using #3holes, but the camber change in the 009 is normal.
Anyone, please? Thank you in advance.
#809
It has just occured to me that there are no other bulkheads, top deck etc attached which means the flex of the chassis is also absorbing a lot of the force. You can actually hear it 'pinging' when struck.
Before someone turns on me as well Rolling Eyes, I will say that I will still be getting my T3 soon, I will probably run the new reinforced brace indoors and the standard items outdoors.
Skiddins
P.S. Does the new brace also have the 'locators' underneath of just the two screw holes?
