Pro 10: 235mm Le Mans Prototype Pan Car Discussion
#3993
Starting point for my Pro10 project, a used Vorlon chassis with Corally axle. It's a very nice piece of kit, especially the slider rear pod. You can get down to 4mm ride-height with new (62mm) tyres.
It needs shocks and a front-end to complete it. I already have spare side-shocks from my F1 project. Will purchase a Tamiya main damper, and an AE dynamic-strut front end.
First step is a complete strip-down, clean and rebuild
#3995
Usually with second-hand cars there's a load of bent bits, stripped screws and problems to sort out, but this was spot on.
#3996
They make this rather interesting kit with small tube dampers, might be good for a Pro10: http://xenon.ocnk.net/product/495
#3997
How to convert...
Hiya folks,
I've recently resurrected my trusty old rc10l with a Roche p10w rear axle and a associated reactive castor front end. Is there any way I can modify the rear pod top plate and add a something to turn it into a three shock(plus t-bar) setup?
#3999
#4000
Actual AE, or a Xenon front end kit?
The damper tubes seem like a nice idea, but I guess you still need to lube the kingpins to keep the suspension smooth, so I'm not sure if you gain much.
The Yokomo YRX12 looks interesting with a double-arm setup, as that shouldn't need kingpin lube. But the parts are expensive.
#4001
Standard AE, mainly as parts are cheap and easy to find.
The Yokomo YRX12 front end does look interesting, but I agree, even more expensive, as well as more difficult to get (I find the Xenon parts to be "normally priced", and with decent availability in the UK, but the AE parts are probably just as good too).
#4002
http://site.petitrc.com/Tech/AE_RC10...on/Aritcle.htm
#4003
what would you use for springs or do you use the stock sprins?
#4004
I don't have that Xenon front end, to be clear.
I'd think you use normal springs, on the kingpin, but the separate damper tubes should provide more consistent damping, compared to just smudging the kingpin?
