Pro 10: 235mm Le Mans Prototype Pan Car Discussion
#3751
#3753
Watch video this he shows you the measurement between a short and regular stack motor.
https://www.youtube.com/watch?v=g9LwWAEBX2g
#3754
A bit less torque and more RPM is what I expected, wondering if there's an effect on overall power, or if it's just a different trade-off? I'm guessing there's an effect, because we can just change the rollout to trade RPM for torque already...
#3755
Yes, what I mean is that since the stator is a bit shorter, it takes a bit less wire to do 13 and a half turns around it.
You were right at the point of saying it: Less turns or shorter stator stack (less wire) is more rpm at a higher current draw. Loss of torque is marginal as brushless has too much anyway. But, it will make the motor feel softer on takeoff. Both work, you just have to move the gearing around to hit the right power band and feel for the track. Most people are too lazy for this and want the magic bullet: Perfect motor, perfect timing, perfect gear ratio and no effort.
#3756
Trade off. It also increases the current the motor pulls.
That's also how a low turn motor is more powerful: it has less absolute torque, but more overall power, you just have to gear down. A 4.5T motor has to be geared at 8.0 (in a touring car), and a 21.5T is able to pull 3.0, but there's no question that it has less overall power, it's not just a trade-off.
#3757
Example: If the number of turns is decreased by a factor of two, the resistance will decrease by a factor of four. First, the wire length is halved, cutting the resistance in half. Then the wire cross-sectional area is doubled to fill up the otherwise empty space on the stator. That's half the resistance again, for a factor of four. So the current also increases by a factor of four. Since torque is proportional to ampere*turns, four times the current times half the turns = twice the torque.
#3758
I'm guessing short stack motors have to have the same gauge of wire (they're used in spec racing, they've got to be maxed out already?), so only a bit less resistance, which means more power, but does the shorter stator reduce the field strength?
In short, if short stacks are so good, they'd just make the short stack version, and not bother with the regular one, so seems like there must be a compromise... Since we can readily trade torque for speed with gearing, it feels like I'm missing something...
#3759
Oh, there's one thing: they must be lighter. With a pan car, that has the motor in the pod, that's good (less unsprung mass).
Even at equal power, that'd be better. Don't see what's "1S" about it, though...
#3760
He compares, specs, weight, stack measurement, amp draw, RPM and etc.
#3761
Roadkill10 ready for testing tomorrow.
#3763
what size tires is everyone running?
#3764
#3765
