Pro 10: 235mm Le Mans Prototype Pan Car Discussion
#2837
Why would you wanna run that front suspension? You can easily mount a newer type of suspension or even the R5 front with the right blocks (hyperdrive or corally)
#2842
The holes on the 10L will fit the hyperdrive and corally blocks. That way, the R5 front will fit...
#2846
#2847
Yes, on this car we are using the AE T/B3 kingpin...
#2848
Hi Pro10noob, I was just wondering about the car in the center picture. what are you trying to achieve by the front end set up? It seems that you were trying to get stiffness by adding the front end plate as well as lower ride height, but it seems to me you are adding flex because of the way that the suspension components hang out beyond the chassis. Is this a custom build or just a Corrally set up that I'm not really familiar with?
#2849
That is a VIP Vorlon chassis in build.
It's made out of 3mm carbon fibre so very little flex.
Not my choice anymore to use a mounting plate though...
#2850
@1spunspur...... What Joost said.
This the stock Vorlon build.
Tobias made this design so you only have to change the front plate to mount a different front suspension brand instead of changing the whole chassis that will cost more.
For me as i am using mostly Associated front end, i let Tobias made the chassis plate to my liking and dimensions.
I wanted the front suspension directly mounted on the chassis and that i why my car(last pic) don't has the loose front plate.
Regards Roy
Regards Roy
