so can anybody help
so can anybody help
i just put a slydr esc and 8.5 motor in my b4. just cause they didnt have a gtb system rmf that wasnt spread spectrum. but i have what seems like an interference problem. it does it for both 27 and 75 Mhz. its when i hit the throttle sometimes it turns sharp right and i have no control till it feels like stopping half a second later. and also when i hit the gas, slowly, it jumps full throttle for a split second then back down. i dunno weather or not i should try my friends 2.4ghz system in it and see if it goes away. i even twisted the 3 wires goin to the motor to help cut down that noise. i just need some opinions.
Sounds like it might be related to voltage drop on power.
How are your batteries? If they are old or poor quality they may be struggling to give enough voltage when the extra power of the brushless comes in.
Also give all your wiring a good going over to check for damage and make sure the antenna runs up through the tube.
Man---- I had the same exact problem with a new Havoc 8.5. Turns out this was caused by my steering servo. I had read somewhere certain servos send backfeed current that causes a bec glitch and has nothing to do with radio. I put a different brand servo in my Losi MF1 and all is well now.
Turned out there was a setting on the ESC for either NiMh or lipo and it was set as default to lipo. This caused the ESC to think it had more power available and when it drew the power the problem occurred.
After I got some help from the guys at the track and changed the setting (20 seconds to fix) I haven't had this issue since.
Hope it helps.
Check for a Lipo setting. But it's not whether or not the steering servo has anything to do w/ it. It's the fact that (for mine) with the setting wrong the ESC would dump too much power and cause a loss of power to the receiver. That's what will cause an erratic sudden turn and loss of throttle.
