Ask Todd Hodge..aka "Hodgimoto"
#511
Bink-The chrome ball stud is LOSA6008. The black ones are LOSA6000. The chrome ball stud lowers your ballstud about .030 which will give you less camber gain the front which results in less steering. The black ball stud is higher which will give you more steering when used in the front.
impactplayr-Kind of....the one main difference with the gas truck is the weight of the engine which causes the back of the truck to roll more. Try Adam Drake's standard setup that is located on the TL website...it is truely the best.
#512
rcman-With the smaller tires you will have to unscrew the shock end to get more travel out of the car. I do this all them time with smaller tires.
lozi-Try weighting your pullies....you can find set screws that you can screw into the holes of the pullies which gives you a flywheel effect when you let off the throttle. Only problem is it may hurt torque since you have to spin more weight now. You can test with this and see what works the best for you...you may only need a few set screws to get the right feel.
#513
Todd,
Can you recomend a good starting setup for outdoors on a large 8th scale track in Scotland for my xxxsg+ using rubber tyres(take offs) and using 19 t motors with reasonably good grip.
I have tried the standard setup and went from there but i feel that I have gone too far in every direction as the car does not seem to be right. I like to run a spool.
PLEASE can you help LOSI GOD.
#514
Drake set-up
Todd- the problem is I am running my NT on a semi-smooth small-medium sized dirt oval.... should the Drake set-up still be pretty good... I am mainly concerned with what changes do what..... and I don't want to hog up the entire on-road section with off-road questions....
I took a look at a fellow racers truck on Sat. and I don't really wanna follow his lead because the truck looked to be sprung too softly and his ride height was far too low for my liking.......
#515
Todd-I finally got to drive a XXXS again-but this time with the Black belt in it and new pullies-All I can say is WOW!!
Also-just bought a MF truck. Do you guys have any data on how much quicker the MF2 is-no other changes? Is it a tenth or something crazy like 1 second per lap?
#516
todd,
for tire diamiter?, what sizes do u run when the tires are 28mm and fresh from the box?? on a losi
thanks lazyboy
thanks lazyboy
#517
BryanD-Email me at [email protected] and I will forward you some of the setups Spashett has given me.
impact-I am here to help anyone with any question so don't worry about that. You can start there and see what it does. You may want to go out on the arm on the rear to get more corner speed on the oval. A softer spring may helps also.
ray-Its about time . j/k!! yea we have really improved the drivetrain as you can see. I really feel the car is super competitive against any other car out there in the stock division. You watch Ray Darroch run the car and its unbelievable....so when are you gonna start running a TL car??
lazyboy-I start all my tires at 58mm.
#519
Hey Todd,
Do you happen to have Hodapp's setup from the Speedworld Cup last year?
#520
jkerr-Running a front diff will make the car easier to drive with a bit more steering. The only problem is that you will not get that forward rip out of the turn.
James-Not sure....email me at [email protected]. If I do I will forward it onto you.
#521
So will these new TRC BBS style rims come with all popular tire compounds on them??
is the TRC marble going to be released?
Later EddieO
Later EddieO
#524
Really? I would take black wheels over white ones any day. Just my personal preference.
#525
Setting Droop w/ Spacers
Hi Todd, what size limiters should I use in the shocks if I'm using spacers to adjust droop? It looks like probably .030 would do the trick front and back. Any suggestions?
