Ask Todd Hodge..aka "Hodgimoto"
#1741
Help Please:
According to this setup sheet, Brian Kinwald used 2DEG OFFSET rear hubs right??
http://teamlosi.com/pdfs/setups/JRXS/C2.pdf
OK then where can I find these 2DEG OFFSET REAR HUBS?? It seems like NOBODY has them...
someone help plz
sorry for posting the same question in the JRXS thread but I gotta get some ASAP...
someone help plz
#1742
Originally Posted by tc3blue
Help Please:
someone help plz
someone help plz
#1743
Originally Posted by BlackKat
Todd: I'm gonna be running 19 turn foam (if they offer it) at the up-comming Region 12 Carpet Championships at Hobbyworld Gilroy. Any advice?
I noticed the US Champs Setup and the ROAR Nats Setup are very similar. I found it a bit odd BK was using a .5 rear sway-bar and none up front. What do the .60 washers on the bellcrank plate & .90 on the knuckle do?
#1744
todd,
will you be making the optional blocks???
thanks
matt
thanks
matt
#1746
Originally Posted by T. Hodge
By running a rear bar and no front the car will just have more steering everywhere on the track. That is how a lot of us tuned our cars last year by changing different thickness of sway bars. As for the bumpsteer, that would of gave BK a lot of bump out...something he always runs. Bump out will make the car steer more in the center of the turn.
Todd-for stock-no matter what set-up i run-its pretty much always has too much mid-off steering in long corners. Its just keep steering into the apex. Can you recommend another bump steer set-up-one thats more neutral steering for stock?
#1747
#1748
OK ladies and gentlemen we have a challange of the team managers....
My moneys on Hodgimoto cause I've seen the size of his head and he can hold lots of brains in there....
#1751
Originally Posted by AdrianM
That was no challenge...I want to know if i'm wrong...lol!
FYI, PW is the team manager
I just sell stuff and race club races like everybody else.
I know I'm right about the brains thing though.....
#1752
Todd - Could you explain how bump toe out gives more steering? That sounds backwards. Bump toe out would cause the tires to turn out of the corner as the chassis rolls...reducing your steering input. Joel Johnson always said bump toe in would give more steering and bump toe out should be avoided.
#1753
Yea...I know my melon is rather large. I feel bad for my wife when we have a child! OUCH!
#1754
you mean 1 degree offset hubs, right?
Thanks!
Thanks!
That depends on what you want. If you want more steering then offset hubs it is. If you are looking for more rear bite then std. hubs work better.
#1755
Go HODGEY GO HODGEY GO GO GO !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
